downpipe dent
Old Mar 27, 2005 | 11:38 PM
homesauce's Avatar
Default downpipe dent
I have a pretty big dent on the bottom of my turbo downpipe, is it possible at all to get this fixed or bent back? The problem is that it's not very accesible because it's pretty much in the middle of the whole dp. I was thinking maybe cutting out a piece and rewelding it?
Old Mar 28, 2005 | 06:49 AM
CRXDrew's Avatar
You could reweld in a piece. Is it on a turn? that would make it a lil harder. You might also be able to get a body shop to weld on a stud and slide hammer it out like a body panel.
I'm in Broadview when I'm not @ U of I... drop me a PM if you need some welding done.
Old Mar 28, 2005 | 08:40 AM
Burntrubber87's Avatar
Default Re: (CRXDrew)
I am not sure if this would work on this peice of piping, but I used to ride motoX. And I used to get bumps and dings and dents all the time on my expensive FMF header pipe. So, I asked this dude who had been riding for a LONG time if he knew a good way to get the dings out. He said, find a cork big enough to fit in one end of the pipe, right? and then made a plug with a hole in it that will fit in the other end, that you can screw a air-tight fitting for say an air compressor in, heat up the dent and the area around the dent with a torch, and using the compressor to pop the dent out. Now, maybe you could find some sturdy rubber to make plugs out of, and try something like that?
Old Mar 28, 2005 | 09:08 AM
homesauce's Avatar
Default Re: (Burntrubber87)
both sound like good ideas, thanks a lot.
Yes, it is on a curved area...
Old Jan 18, 2006 | 08:54 AM
GPNY's Avatar
Default Re: downpipe dent (homesauce)
back from the dead... I need to fix my downpipe :-(
350 miles old, custom SS and a huge dent now...
Old Jan 18, 2006 | 06:36 PM
discrete's Avatar
Default Re: downpipe dent (GPNY)
Is it in the straight section or a bend?
Do you want to spend a lot of money or a little?
Old Jan 19, 2006 | 08:37 AM
GPNY's Avatar
Default Re: downpipe dent (discrete)
My dent is in the bend and extents into the straight.
I don't plan on spending much to fix it.
Do you have suggestions on repairing it easily, or do I need to cut and reweld...
My thoughts were to cut the dented section with a plasma cutter, bang it back into shape, and reweld it on... It would just take a few hours...
Old Jan 19, 2006 | 12:13 PM
BodyKits NW's Avatar
I got a dent in my full race downpipe. I didn't loose any power last time I went to the dyno.
If I remember correctly my friend fixed his downpipe by drilling a hole and he got the dent hot enough that he was able to pull it out. I forget how exactly he did it, but it was something along those lines.
Old Jan 19, 2006 | 01:29 PM
mopar junkie's Avatar
You can make a tool like the PDR (paintless dent repair) folks do. Basically a really strong rod with a bend on one end and a handle on the other. Heat up the dented area and work it smooth from the inside.
It's probably a waste of time though.
Old Jan 19, 2006 | 03:25 PM
GPNY's Avatar
Default Re: (mopar junkie)
Yeah... except I'm using really thick tubing... Schedule 80 I think for the DP...
I made my stuff out of surplus SS from a chemical plant. The tubes they use are much thicker than regular exhaust tubing...
Old Jan 19, 2006 | 07:08 PM
Evile140's Avatar
Drill a hole on the opposite side of the downpipe then use a punch/BFH to drive the dent out. then weld the hole closed.
Later
Randy
importdreamer
Sep 17, 2008 04:18 PM
hybrid2007
Welding / Fabrication
12
Dec 1, 2007 11:30 AM
legendboy
29
Dec 28, 2005 01:28 PM
bostoncal
Nov 23, 2005 02:44 PM
Optiks.
Jan 9, 2003 01:24 PM
