DIY mandrel downpipe
Old Jan 8, 2003 | 05:54 PM
Optiks.'s Avatar
Default DIY mandrel downpipe
how hard do you think this would be just get some SS exhaust tubing cap it of on one end and pack it tightly with all purpose sand then heat with torch and bend ???
Old Jan 8, 2003 | 06:07 PM
rjardy's Avatar
Default Re: DIY mandrel downpipe (Optiks)
Me personally, i would just spend the 6 dollars on the pre bent peice.
Rob
Old Jan 8, 2003 | 06:26 PM
dmotoguy's Avatar
Default Re: DIY mandrel downpipe (rjardy)
where can you find a downpipe for $6?
Old Jan 8, 2003 | 07:19 PM
CzanSOHC's Avatar
Default Re: DIY mandrel downpipe (dmotoguy)
he is just talking about how much a mandrel bend will cost....they are about $15 -$20 for stainless steel at jegs.com.
Old Jan 8, 2003 | 07:26 PM
dmotoguy's Avatar
Default Re: DIY mandrel downpipe (CzanSOHC)
i know but i think the guy doesnt want to have to cut prebent pipe and re-weld it into a downpipe.. i think he wants to do it all in one piece, and i think his idea might work, but then again, it would be really hard to bend the pipe with the sand inside, it would take A LOT of force
Old Jan 8, 2003 | 07:37 PM
CzanSOHC's Avatar
ok, i see...yea that would be hard...alsogetting it bent in the perfect shape to make everything line up would be a bitch...
hey...dmoto...do you rember me from Speedoptions.com...i used to post there all the time until mike got his panties on a bunch...
Old Jan 8, 2003 | 07:58 PM
evoeone's Avatar
mandrel bends, flanges, bungs, gaskets, cut and weld and presto...you have a new exhaust system, and muffler if needed
Old Jan 9, 2003 | 11:31 AM
Optiks.'s Avatar
good point but i can get a long peice and and bend it like this, i know the sand method works because my dad used the method in the 70's in tech college so hey must work, BTW is there any difference between the tubing they use in DP's then just regular exhaust tubing?
Old Jan 9, 2003 | 11:42 AM
evoeone's Avatar
if youre making a dp only, chances are its omly about 2-3ft long at the most, 2 bends will cost the same as a 3-4ft staright piece. just buy the bends, it will be easier IMO
Old Jan 9, 2003 | 01:24 PM
dmotoguy's Avatar
Default Re: DIY mandrel downpipe (evoeone)
Czansohc- i remember you
it would be the easiest to just go to a muffler/exhaust shop, but if you want to DIY just get pre bent piping, cut and weld, it wont be that hard to do at all... if you can weld
rs250nut
Welding / Fabrication
Jan 22, 2013 12:41 PM
airwalk07143
Jun 5, 2008 11:58 AM
champLSinteg
Sep 7, 2006 01:25 PM
VspecSiR
Jun 25, 2006 03:37 PM
opto_isolator
Jul 31, 2004 10:14 PM
