B series omnipower valvetrain??
Old Mar 27, 2005 | 09:31 AM
Meshmasteryow's Avatar
Default B series omnipower valvetrain??
Has anyone on here tried the valves or vavlesprings from omnipower yet? If so, do you like them?
Old Mar 27, 2005 | 09:36 AM
Kendall's Avatar
Omnipower
They don't have incredibly high seat pressure, so you do need to be careful not to run too big of a cam with them, or valve float may be an issue. On the flipside, your cams and valvetrain will last a lot longer than they would with stronger springs as there's less force pushing on everything.
Old Mar 27, 2005 | 10:38 AM
Cory Matthews's Avatar
Default Re: (Kendall)
i dont like omni power, there tooo new for me. stick with whats tried and true.
Old Mar 27, 2005 | 12:28 PM
What kind of compression are they supposed to make? Ive got a jdm b16a and im using civic type r pistons and itr camshafts, you have any idea what it might be with the omnipower setup? I just know that on the site it says they are flat on the end to increase comp. Thanks.
Old Mar 27, 2005 | 12:52 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: (Meshmasteryow)
Omnipower is quality stuff, i have the flat faced valves in my ls vtec. Trust me, Steve would not put his name on something if it wasnt a quality product. Im pretty sure you will be happy with any of his products. good luck with your build.
Old Mar 27, 2005 | 07:37 PM
Default Re: (PURPLETERROR)
Thanks guys, how high do they raise comp. ? How effective do you think the itr cams will be? Im trying to build a jdm b16a with stock reliability and gas economy with an increased powerband all the way across, so far this is what im doing= Complete rebuild with civic type r pistons and rings, stock rods, stock crank just balanced and polished, ported and polished head, itr cams with omnipower valvetrain, stock intake mani. w/ hondata gasket and Hondata s200. I don't really think ill need more fuel, what about you guys?
Old Mar 27, 2005 | 08:20 PM
DunDaDa_EK9's Avatar
Default Re: B series omnipower valvetrain?? (Meshmasteryow)
omni power is real nice i would buy from them again dundada
Old Mar 27, 2005 | 08:24 PM
Frozen E's Avatar
H-T White Ops
How do you think they'd do on a built 9:1 B16, stock cams, running about 16-18 psi?
Old Mar 30, 2005 | 07:57 PM
bump?
marshall12395
Jan 1, 2013 03:51 PM
vtecturbo18
Oct 16, 2009 06:01 PM
p0gi_b0i_integra
27
Nov 29, 2007 10:17 PM
skoodles2k6
Sep 19, 2007 10:10 PM
BOOSTIN1
Feb 17, 2006 01:29 PM
