:URGENT: need clutch help....
Old Mar 26, 2005 | 11:41 PM
hondainspired's Avatar
Default :URGENT: need clutch help....
ok here is the story...... sorry in advance
i was at a red light... playin puttin the car in and out of reverse several times because of boredem.... light turns green and the car stalls... so i'm like ok... i'm a ****** idiot and jus stalled the bitch... start it back up and it wont go into gear... but i still had pedal the clutch just wouldn't engage so i'm screwin around lookin at the fluid (which was black as hell) and i'm pumpin and pumpin and pumpin.... well i manage to get it in fifth gear (which syncronizes reverse) and managed to get it into reverse and back it into a gas station.... i get the car in the gas station where i want it so its out of the way and now it'll go into all the gears... so i drive it around the gas station and its just fine... so i drove home...and ideas to what this might be leading to so i can catch it now... i'm going to bleed the clutch tommarow with some new fluid and hopefully that will help but i've noticed i also have the well known squeek as i'm disengaging the clutch... (and dont tell me master and slave cly. cause i've been through all that ... if it was those i wouldn't have any pedal..) it was just a weird situation...
THANKS FOR THE HELP IN ADVANCE.... if i get any lol.....
Old Mar 27, 2005 | 06:35 AM
BatuKing's Avatar
Default Re: :URGENT: need clutch help.... (hondainspired)
get a friend and see if the slave moves the fork and if it does see how much.
check the fluid in your tranny also
Old Mar 27, 2005 | 09:48 AM
Default Re: :URGENT: need clutch help.... (BatuKing)
ok sounds good...
Old Mar 27, 2005 | 09:54 AM
SPEEDQUEST INC.'s Avatar
The exact same problem happened to my H22, it's so weird! I Bleed the Clutch pedal and it seems fine now, See what happens after driving it for a while and keep an eye on the slave cylinder... good luck
Old Mar 27, 2005 | 09:57 AM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondainspired &raquo;</TD></TR><TR><TD CLASS="quote">ok here is the story...... sorry in advance
THANKS FOR THE HELP IN ADVANCE.... if i get any lol.....</TD></TR></TABLE>
5th does not syncronize reverse, reverse does not have a syncronizer.
you are doing the right thing, flush and bleed see where that gets you.
Old Mar 27, 2005 | 10:32 AM
Default Re: :URGENT: need clutch help.... (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">
you are doing the right thing, flush and bleed see where that gets you. </TD></TR></TABLE>
due to your post count i'll believe you... i was just always told that it does... thats why i always put it in 5th before i put it in reverse so it doesn't grind when i put it in reverse...
Old Mar 27, 2005 | 10:40 AM
Kamin's Avatar
lol my post count has nothing to do with this. there is no syncronizer in reverse thats why you grind to begin with going into that gear
youll find if you go into 4th before reverse it shouldnt grind eithre
Old Mar 27, 2005 | 10:47 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">lol my post count has nothing to do with this. there is no syncronizer in reverse thats why you grind to begin with going into that gear
youll find if you go into 4th before reverse it shouldnt grind eithre </TD></TR></TABLE>
still by your post count being so high and you being an 01 member tells me there is knowledge... thank you for the help... i'm gonna see what happens after i bleed the fluid and check the slave cly. and i'll get back at you guys
Old Mar 27, 2005 | 08:43 PM
BatuKing's Avatar
FYI 2nd is attached to reverse, so go into second then go into reverse
Old Mar 28, 2005 | 07:01 PM
so basicly either gear will....
Old Mar 29, 2005 | 09:26 AM
IT DID IT AGAIN THIS MORNING WHEN I GOT TO WORK&gt;... AND I BLED THE FLUID LAST NIGHT.... i think its jus the slave cyl. i dont wanna shell out 60 bucks for it though
Old Mar 29, 2005 | 09:32 AM
Kamin's Avatar
get one from autozone. 20$
Old Mar 29, 2005 | 07:09 PM
I have a 99 GSR one, and i live by the area, Let me know if interested,
Old Mar 30, 2005 | 02:27 PM
Default Re: :URGENT: need clutch help.... (SkunkEk)
autozone it is...
Old Mar 30, 2005 | 06:49 PM
how do i know if the clutch is done.... cause i jus replace the slave cly., bled the clutch really good and adjusted the freeplay... well.... it still everyonce in a while refuses to let me put it in gear... and i drove it around and the clutch is makin all kinds of sqeeking noises and **** like that... (searching for a trans writeup)
Old Mar 31, 2005 | 01:45 PM
bump
Old Mar 31, 2005 | 03:35 PM
EVIL TYPE R's Avatar
If your car won't let you put it in gear when it's running...turn it off and try it with it off, if it goes in easy when it's not running your clutch needs to be replaced. This is very common when the springs in the clutch get loose and are ready to fall out. It's only going to get worst and eventually your going to need to get it towed to fix it, so take it somewhere while you still can!
Old Apr 3, 2005 | 07:20 PM
Default Re: :URGENT: need clutch help.... (EVIL TYPE R)
DAMN IT.... ahh well... guess that jus means light flywheel and better clutch for me...
Old Apr 3, 2005 | 07:49 PM
slambedcivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BatuKing &raquo;</TD></TR><TR><TD CLASS="quote">
FYI 2nd is attached to reverse, so go into second then go into reverse </TD></TR></TABLE>
the reverse gear is on its own shaft.... what are you people talking about? the only reason reverse doesnt grind when you touch ANY other gears prior to reverse is because the syncros are slowing the internals in the tranmission down.
Old Apr 4, 2005 | 06:17 AM
Default Re: :URGENT: need clutch help.... (slambedcivic)
so slambedcivic would you support Eviltyper's statment?
arentzy
Mar 18, 2014 05:52 PM
ml21
Dec 4, 2010 07:38 PM
kelviiv
Sep 18, 2008 05:38 PM
stilzx61
Honda S2000
Aug 28, 2008 12:05 PM
teg-96
Aug 12, 2007 12:00 PM
