97 ek rear dics mix and macth
Old Mar 21, 2005 | 06:28 PM
xoutlawz00x's Avatar
Default 97 ek rear dics mix and macth
i got a 97 ek and i just put 99 rear disc on... can i put intergra 94-01 Master cylinder proportional valve and booster on to increase its effectiveness!
1 i can't fine them part from a 99-00 si integras are easier to find
2. my brakes no matter how many times i bleed them they are still soft.. i think its the master cylinder
Old Mar 22, 2005 | 02:11 PM
Default Re: 97 ek rear dics mix and macth (xoutlawz00x)
does anyone know???
Old Mar 22, 2005 | 02:13 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
The booster and MC i think u can put on from the integra, but the prop valve has to be from a 99-00 SI, because the integra ones are completely different. Make sure u bleed them right too. Search for a thread with correct bleeding procedure. It makes a huge difference.
Old Mar 22, 2005 | 02:46 PM
Default Re: 97 ek rear dics mix and macth (rukawa1one)
k thanks
Old Mar 22, 2005 | 03:01 PM
igone916's Avatar
I got the same swap but wit 94 integra front brakets wit 99 si rear disk on my ek hatch...i didn't change my brake master cylinder, brake booster or ppv and it still brakes hard...did you bleed all 4 brakes...
Old Mar 22, 2005 | 03:22 PM
Default Re: 97 ek rear dics mix and macth (igone916)
yea i bleed all four like **** 5 times... and brakes still is not hard how can i tell if its my master cylinder
Old Mar 22, 2005 | 03:38 PM
pdiggitydogg's Avatar
with the car off, press and hold down on the brake pedal...if it continues to slowly sink to the floor, your mc is bad.
I advise that you swap ou the mc/bb for a larger unit, bend the lines, and get an em1 prop valve (if you dont have a hatch - hatches and the em1 si have the same prop).
Old Mar 22, 2005 | 06:24 PM
Default Re: (pdiggitydogg)
yea i have a hacth ill do that test
Old Apr 3, 2005 | 04:05 PM
Default Re: (xoutlawz00x)
what are my option for a larger bb/mc??? si 99-00 or integra 94-01 ???
Old Apr 3, 2005 | 06:07 PM
Sialove's Avatar
you can use integra rs mc/bb all lines and everything match up i just did it but i cant seem to get a brake pedel i guess that there is air in the lines somewhere dunno replaced mc/bb/pro valve and still nothing but the rs stuff bolts right up to everything
EKSedAndy
15
May 2, 2010 09:39 PM
92'si
13
Mar 31, 2009 03:35 PM
96Spec Ek
Dec 13, 2005 06:50 PM
igone916
10
Oct 24, 2004 05:46 PM
90teg
Aug 9, 2004 02:49 PM
