vtec vs i-vtec, difference??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DxHatch99 »</TD></TR><TR><TD CLASS="quote">i knew that much, the RSX's and **** have i-vtec, although never seen a new honda under 99 with an i-vtec motor..</TD></TR></TABLE>
thats because thats not new, hes talking about the new k20s
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcoupe94 »</TD></TR><TR><TD CLASS="quote">but i dont know much about the newer honda engines
dont feel bad, niether do i
there are ek civics out there with a k20 i-vtec motor in them, but they didnt come like that from the factory.... i-vtec comes only in the new Si's and both RSX and RSX-S...I could be wrong, Im not sure if the s2k's with and f22 have i-vtec
Honestly if you have any questions about i-VTEC, or K20s this is the man to talk to:
https://honda-tech.com/zerouser...01149
Or check out his own site:
K20A.org
K20A.org
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blue00vtecsi »</TD></TR><TR><TD CLASS="quote">The I stands for intelligent Vtec so I guess its smarter
lol, in your opinion people, what do u think is better vtec or i-vtec (i hope i don't start a huge arument...)
</TD></TR></TABLE>lol, in your opinion people, what do u think is better vtec or i-vtec (i hope i don't start a huge arument...)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Milanogisser »</TD></TR><TR><TD CLASS="quote">Think of it as a combination of sohc vtec and dohc vtec.You get race spec cam lobage complimented by stock cam gears advancing! did i confuse you?</TD></TR></TABLE>
lol just a lil bit
lol just a lil bit
i know this is a really stupid question.. but i don't know whether to buy a complete swap, or buy the block, and the rest serperately... but altogether.. what do i NEED in order to have a nice complete swap.. LIST EVERYTHING!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DxHatch99 »</TD></TR><TR><TD CLASS="quote">i know this is a really stupid question.. but i don't know whether to buy a complete swap, or buy the block, and the rest serperately... but altogether.. what do i NEED in order to have a nice complete swap.. LIST EVERYTHING!!</TD></TR></TABLE>
i would buy the complete swap unless for some reason you could peice together a full swap for less.
BTW: Bseries ownz all
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedJeff »</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>+1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedJeff »</TD></TR><TR><TD CLASS="quote">BTW: Bseries ownz all </TD></TR></TABLE>
riiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iight
I'd like to see you find a cheap b-series in working condition in 5 years. And plus, for the money it costs to make the same power a k20 does in a b-series, you could probably have another 50-80 hp in a k20............. k>*
Unlike VTEC operation VTC operates continuously throughout all engine speeds and throttle positions. The intake cam can be advanced by as much as 50 degrees. Advancing the cam at part throttle generates an EGR effect where some exhaust gas enters the intake. Oil pressure fed to either side of the lobes in cam advance mechanism allows the ECU to continuously advance or retard the cam to meet either emissions or power requirements. As far as power is concerned this allows Honda to optimize torque across the entire rev range. <<Hondata
^^^^^^^ Ek hatch wit k20a turbocharged built by Full Race in Phoenix AZ
maybe i could be wrong, but i think i read somewhere that i-VTEC engages whenever you floor the gas pedal, on the new si's and rsx's,
as to VTEC only engages like after 4,600 rpm depends on what motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ejay1 »</TD></TR><TR><TD CLASS="quote">its invisible
Its intelligent.
</TD></TR></TABLE>Its intelligent.
There's quite a bit of misinformation floating around in here.
http://auto.howstuffworks.com/question229.htm
http://auto.howstuffworks.com/....html
Check out 3-stage VTEC on the second link. Basically it works like VTEC-E at low RPM's, then the B / D series VTEC that we're familiar with at high RPMs. Search around a bit, then come back if you still have questions.
is the VTC you are talking about the same VTC that nissan uses?
I know on my 92 Maxima SE, it has the notorious "VTC ticking" problem
I need to sell that damn car...been sitting outside for a while now
