HELP! Temperature gauge goes down in VTEC??
Old Mar 15, 2005 | 09:00 AM
Demented's Avatar
Default HELP! Temperature gauge goes down in VTEC??
Heres my setup
1994 RS
built/sleeved b18a block
gsr head
jdm vtec solenoid
stock p28 auto jumped to manual
I have A4 to my vtec solenoid and D6 grounded. No CEL's.
Vtec works fine, temp gauge reads line below half. When Vtec kicks in my temp. gauge goes down. When Im out of vtec it goes back up to normal. Any answers please. Thanks.
Help tried searching
Old Mar 15, 2005 | 09:55 AM
Demented's Avatar
Default Re: HELP! Temperature gauge goes down in VTEC?? (Demented)
up
Old Mar 15, 2005 | 11:25 AM
virusiidx's Avatar
does the needle drop down right away, or goes down gradually like if the temp is actually cooling down quick.
Old Mar 15, 2005 | 11:30 AM
Slain's Avatar
might want to take a look at your thermostat
NeoGSR's Avatar
Default Re: (virusiidx)
my car used to do this when i'd hit 5700, not vtec, but it would drastically fall, the problem was the thermostat....replaced it and took care of it.....
Old Mar 15, 2005 | 12:13 PM
AlxSiR7's Avatar
Default Re: (NeoGSR)
maybe you're just going faster and the motor is cooling off... it happens.
Old Mar 15, 2005 | 12:14 PM
Slain's Avatar
it wouldnt drop down like that lol. i remember when my tstat went out.. i was hauling *** down a onramp and noticed my temp gauge going towards the c lol.
Old Mar 16, 2005 | 08:46 AM
Demented's Avatar
Default Re: (Slain)
alrite thanks guys I'll replace it with a honda one.
Old Mar 16, 2005 | 10:15 AM
vidanator's Avatar
Default Re: (Demented)
my temp gause kinda does that too, when i'm at operating temp. and then accelerate pretty fast and put it above 5500, the temp goes down a little bit, but not too much but it is noticable, but it does go back to operating temp pretty much right after i'm done accelerating, i don't think there is any problems, i also think the engine is just cooling down faster
Old Mar 16, 2005 | 10:16 AM
EFz6er's Avatar
Default Re: (vidanator)
my temp guage is screwy too, but it just stays at like a 1/4 of the way up. You guys think thas the thermostat as well?
Old Mar 17, 2005 | 07:30 AM
virusiidx's Avatar
Default Re: (EFz6er)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFz6er &raquo;</TD></TR><TR><TD CLASS="quote">my temp guage is screwy too, but it just stays at like a 1/4 of the way up. You guys think thas the thermostat as well?</TD></TR></TABLE>
yup, thermostat, im having the same problem.
Old Mar 17, 2005 | 09:06 AM
Demented's Avatar
Alrite coo thanks
Old Mar 17, 2005 | 09:34 AM
honda011's Avatar
my thermostat goes down to cold when on the highway, and when im driving normal it's regular...
Old Mar 17, 2005 | 11:59 AM
EFz6er's Avatar
Default Re: (honda011)
which thermostat shoud I get...they have different tempature ones. Which one for a basically stock B18 with I/H/E.
Old Mar 17, 2005 | 12:02 PM
virusiidx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFz6er &raquo;</TD></TR><TR><TD CLASS="quote">which thermostat shoud I get...they have different tempature ones. Which one for a basically stock B18 with I/H/E.</TD></TR></TABLE>
stick with the oem one, its like 12 bucks or something.
Old Mar 17, 2005 | 04:21 PM
Keno20's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vidanator &raquo;</TD></TR><TR><TD CLASS="quote">my temp gause kinda does that too, when i'm at operating temp. and then accelerate pretty fast and put it above 5500, the temp goes down a little bit, but not too much but it is noticable, but it does go back to operating temp pretty much right after i'm done accelerating,</TD></TR></TABLE>
Mine does the same thing, but only when my car has just warmed up. If ive been driving around for a while then accelerate heavily nothing happens it just stays the same.
Old Mar 17, 2005 | 04:41 PM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Demented &raquo;</TD></TR><TR><TD CLASS="quote">jdm vtec solenoid</TD></TR></TABLE>
LMAO!!
*Wipes tears from eyes*
Yeah, it sounds like a bad thermostat. It's probably stuck open. Does your car take an unusually long time to warm?
JDM VTEC solenoid... BAHAHA!!!
Old Mar 18, 2005 | 06:18 AM
EFz6er's Avatar
Default Re: HELP! Temperature gauge goes down in VTEC?? (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by virusiidx &raquo;</TD></TR><TR><TD CLASS="quote">
stick with the oem one, its like 12 bucks or something.</TD></TR></TABLE>
Well there are high temp, med. temp and low temp....what are the differences?
So if I got this one http://cgi.ebay.com/ebaymotors...WDVW it fools the car into thinking is cooler than it is. I just want a OEM one but even acurapartsstore.com had different temp. thermostats
Old Mar 18, 2005 | 08:44 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: HELP! Temperature gauge goes down in VTEC?? (EFz6er)
Well there are high temp, med. temp and low temp....what are the differences?</TD></TR></TABLE>
In general, a lower temperature thermostat yields more power and less fuel economy. The lower temperature allows for more aggressive ignition timing without knocking.
Old Mar 18, 2005 | 08:48 AM
Demented's Avatar
So whats so funny about a JDM VTEC solenoid!! DOGG!!
Old Mar 18, 2005 | 09:35 AM
EFz6er's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Demented &raquo;</TD></TR><TR><TD CLASS="quote">So whats so funny about a JDM VTEC solenoid!! DOGG!!</TD></TR></TABLE>
Itz G()Tz M4d VtAcHs y0
Old Mar 18, 2005 | 09:49 AM
Demented's Avatar
FIY most jdm vtec solenoids have no vtec oil pressure sensor. So thats why i added it on my original post. Thninking it may be a wiring problem.
Old Mar 18, 2005 | 10:06 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Demented &raquo;</TD></TR><TR><TD CLASS="quote">FIY most jdm vtec solenoids have no vtec oil pressure sensor. So thats why i added it on my original post. Thninking it may be a wiring problem.</TD></TR></TABLE>
It made me laugh, that's all.
The solenoid is the same p/n, the body is different. Regardless, it shouldn't matter in your situation as the VTEC is still engaging. It sounds like a sticking thermostat.
1ls/vtec
Mar 3, 2011 03:26 PM
everythingwentblack
16
Mar 3, 2008 08:25 PM
SPEEDQUEST INC.
13
Mar 16, 2005 08:52 AM
Demented
Mar 16, 2005 08:50 AM
