wierd idle problem
Old Mar 14, 2005 | 05:31 PM
toyzbus's Avatar
Default wierd idle problem
I am having problems with a friend's Civic that I have been working on. It is a 94 Civic with a boosted b16a2 swap w/ a p61 ecu. The car will idle fine when the car is cool, but will not idle at all when the engine gets up to normal operating temps. Before, the car would have a jumping idle, but I took off the throttle body and cleaned it as well as the idle air passage. The jumping idle seems to be gone, but the car will only idle when the ecu is in open loop. Any suggestions or comments?
Old Mar 14, 2005 | 07:50 PM
toyzbus's Avatar
Default Re: wierd idle problem (toyzbus)
Old Mar 15, 2005 | 06:34 AM
PrettyLude's Avatar
FITV, right under your throttle body with the coolant lines running to it, take it apart and adjust the plunger back in
Old Mar 15, 2005 | 06:35 AM
CompressionFed's Avatar
Have you checked for vacuum leaks? What condition is your IAC in?
Old Mar 15, 2005 | 07:34 AM
mmuller's Avatar
Mad Scientist
Default Re: wierd idle problem (CompressionFed)
check your iacv. adjust yuor idle a lil to see if it helps
Old Mar 15, 2005 | 11:12 AM
toyzbus's Avatar
IACV is brand new, I am leaning towards it being the FITV I doubt that there is a vacuum leak beings that the thing idles great during open loop.
Old Mar 15, 2005 | 11:55 AM
PrettyLude's Avatar
the thing that makes me think its the FITV, is when he says that it only does it when its warm
ITR EG
Apr 12, 2008 09:29 PM
averyvm
17
Jan 17, 2007 11:51 AM
Midori Green
Jan 3, 2007 03:13 PM
chrisbell37
Aug 25, 2006 12:31 PM
SilverSellout
12
Feb 27, 2004 12:48 PM
