Need Help!!!!! Radiator fan not working
Old Mar 14, 2005 | 09:45 AM
IrOcKtHeVOrTeC's Avatar
Default Need Help!!!!! Radiator fan not working
Like what it said.... need help guys. everytime I sit in a drive thru my temp goes up.... and the fan does not go on.
Old Mar 14, 2005 | 11:02 AM
stareatsun's Avatar
Check the radiator fan relay. Make sure everything is plugged in. Thermoustat good condition? Anything stopping the fan?
Old Mar 14, 2005 | 11:07 AM
BlownVR's Avatar
Default Re: (stareatsun)
If everything else fails and still doesnt work then get 2 wires run them from the 2 wires on the fan and into the car, put one as ground then one into a 12v source then hook them both up to a switch and be good to go, you can do it for verry cheap and easy solution. $5 for swith and $3.50 for wiring. I did it with ease in 30 min.
Old Mar 14, 2005 | 11:51 AM
IVI's Avatar
IVI
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stareatsun &raquo;</TD></TR><TR><TD CLASS="quote">Check the radiator fan relay. Make sure everything is plugged in. Thermoustat good condition? Anything stopping the fan?</TD></TR></TABLE>
first make sure the fan would even turn on by shorting it.
then check the relays, coolant temp sensor, etc.
Old Mar 14, 2005 | 01:02 PM
Default Re: (IVI)
nothing is stoping the fan...... were would I fin the relay...... sorry I hate electircal work.
Old Mar 15, 2005 | 09:55 AM
Default Re: (IVI)
Hey thanks for the help..... question were would I find the fan relay?
Old Mar 15, 2005 | 10:33 AM
WTB AUTO EK's Avatar
Default Re: (NismoSpec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NismoSpec &raquo;</TD></TR><TR><TD CLASS="quote">If everything else fails and still doesnt work then get 2 wires run them from the 2 wires on the fan and into the car, put one as ground then one into a 12v source then hook them both up to a switch and be good to go, you can do it for verry cheap and easy solution. $5 for swith and $3.50 for wiring. I did it with ease in 30 min. </TD></TR></TABLE>
this is a good idea. but try to fix it to the original settings. i did the same thing and i got bs for modifiying my coolant system when i went to go get my moms car smogged.
EGed up from the seat up
18
Jun 1, 2011 02:16 AM
ShinotakuX
Dec 14, 2007 08:20 PM
Lo0z3rCIVICBoi
May 8, 2006 06:24 AM
EF8 JUNKIE9
15
Aug 27, 2005 08:35 PM
fathergoose
Jun 8, 2003 06:01 PM
