Radiator Fan still won't come on after...
My radiator fan still won't come on after checking all fuses, relays, changed the coolant temperature sensor, and I even changed the thermostat.
Usually the radiator fan comes on on a warm summer day when the A/C fan comes on, however this is not the case the past few days. The fan motor is fine also, anybody else have any suggestions? I would appreciate any help.
-Lo0z3r
-Lo0z3r
Re: Radiator Fan still won't come on after... (Jedi_Sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jedi_Sol »</TD></TR><TR><TD CLASS="quote">You tried jumping the fan too?</TD></TR></TABLE>
try this to make sure the fan is working. then test all wire to make sure you have a good connection. also check the harness wire that goes into the thermostat. mine was not melted from the past that i didnt know about and wasn't in all the way, had same problem.
Re: Radiator Fan still won't come on after... (Lo0z3rCIVICBoi)
The fan hasn't come on with either of the GE's that I've had unless it was hot enough for them to turn on.
Is your car running hot?
Re: Radiator Fan still won't come on after... (scuzz)
take off the fuse box lid in the engine bay, remove radiator fan relay and jump it there, that way you know if your wiring is working or not. Obviously, jump it when the car is running, or key is all the way forward.
AgentJam
07-01-2005 05:23 AM
