sorry searched where is the acg fuse located for a ek
i have been searching! my car has no fuel and no spark
the list of parts i have changed
distributor
main fuel relay
fuel pump
ecu fuse
i hae changed everything
and now i was searching and found that the acg fuse can cause this and i dont know where it is
here is the background on my car the car was stolen and then clipped my ecu out of the car so i put a new engine harness in it they broke the igntion so i put a new one in and now i dont have any fire or fuel
Modified by hatchbackhonda at 12:42 AM 3/15/2005
distributor
main fuel relay
fuel pump
ecu fuse
bump i need to figure out if this is the problem c-mon people no spark and no fuel
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bunnyrabbit »</TD></TR><TR><TD CLASS="quote">did you check in your ******* man?? that might work</TD></TR></TABLE>
What the **** kind of statement is that
Anyway, I think its under the dash, the 15a fuse located right next to the SRS fuse (in the 12, or 24 spot I think) Also, I think the ACG fuse is for your alternator.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smithenhiven »</TD></TR><TR><TD CLASS="quote">I think its under the dash, the 15a fuse located right next to the SRS fuse (in the 12, or 24 spot I think) Also, I think the ACG fuse is for your alternator.</TD></TR></TABLE>
the ACG fuse can give symptons of a bad fuel pump/main relay. figured that out the hard way haha that's why it's always good to check ALL of your fuses instead of the ones you think might be associated with the problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchbackhonda »</TD></TR><TR><TD CLASS="quote">here is the background on my car the car was stolen and then clipped my ecu out of the car so i put a new engine harness in it they broke the igntion so i put a new one in and now i dont have any fire or fuel</TD></TR></TABLE>
What car did this happen to????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bunnyrabbit »</TD></TR><TR><TD CLASS="quote">its a 98 civic w/ gsr swap, i originally got the car and traded it to tyler</TD></TR></TABLE>
lol, I guess that would explain your off the wall comment earlier
My Honda Blows
Dec 22, 2022 02:12 PM
cars
10
Aug 3, 2010 03:30 PM
team_lunatics
12
Apr 3, 2009 03:30 PM
btbomb
Oct 10, 2007 03:22 PM
