SparkPlug Tech Questions (Turbo Application)
Old Jan 23, 2002 | 10:09 AM
BluLuder's Avatar
Default SparkPlug Tech Questions (Turbo Application)
I use Denso Iridium Plugs right now.. but I think Im going to get some cheaper ones since I hafta change them more frequently with the turbo. I had a couple of questions: I was looking into some NGK the ZFR' _ _?s. What is the gap to set at (36mm?)
How long will the Copper last me compared to the Platinum or Iridiums? Any other recommendations on plugs for my Turbo'd H23a?
Old Jan 23, 2002 | 11:10 AM
976's Avatar
976
New User
Default Re: SparkPlug Tech Questions (BluLuder)
Since you're running a turbo'd engine, it technicaly runs hotter. Use NGK ZFR6F-11 spark plugs, they are recommended for high heat engines. You can also try ZFR7F. Take those denso's high price tags and shove em' in the direction of where you bought them...
Old Jan 23, 2002 | 01:11 PM
boomslang's Avatar
Default Re: SparkPlug Tech Questions (B21A)
Use NGK zfr7f-11 sparkplugs. Gap them at .030"
There is also an NGK plug available at Honda Marine shops, it's the same plug as the one above, except it is pre-gapped to ~.032, and has a different designation.
Old Jan 23, 2002 | 05:03 PM
DirtyLude's Avatar
Default Re: SparkPlug Tech Questions (Inlinefour)
Ya, dont' get the 6f's that's the stock heat range. At least get the 7f's.
Or you can get bkr7e-11. They're essentialy the same, but the tip isn't quite as extended and they're a little cheaper and easier to find.
Old Jan 25, 2002 | 01:42 PM
BluLuder's Avatar
Default Re: SparkPlug Tech Questions (DirtyLude)
I looked for the ZFR7's but they didnt have them on hand. So I figured Id be ok with the Copper NGK - BKR 7Es and got them
I was gonna gap em to 32mm is this seem right?
Old Jan 26, 2002 | 06:04 AM
boomslang's Avatar
Not 32 mm, 0.032 inches.
Old Jan 26, 2002 | 06:12 PM
93H22A's Avatar
i use BKR-7E11 order from sparkplugs.com $2 part 1283, one step colder
Old Jan 28, 2002 | 12:30 AM
wutangben's Avatar
Default Re: SparkPlug Tech Questions (93H22A)
i would go with either the ngk's previously mentioned (the 7 series) or the Zex plugs, which are 2 heat ranges colder.
(i personally have the zex plugs)
peace
TravisBiggie
Jul 23, 2012 03:25 PM
B18B1DOHC
Nov 17, 2003 02:08 PM
SpeedMonkeyRacing
Apr 24, 2003 08:55 PM
01ITR#700
Feb 16, 2003 12:50 PM
skrewdlude
Sep 22, 2002 03:52 PM
