knock sensor
Old Mar 12, 2005 | 10:03 PM
hatch34's Avatar
Default knock sensor
i have a obd1 GSR in my EG and i keep throwing code 23 but it will turn off if i turn the car off. not really sure how big of a problem this is can it cause major problems if i just keep letting it go. oh yea and the motor is stock no big lift cams or anything like that to make lots of noise just normal old GSR. anythin will help.
Old Mar 12, 2005 | 11:27 PM
Ls_V_TurboSi's Avatar
Default Re: knock sensor (hatch34)
I'd say just replace it to be on the safe side
Old Mar 13, 2005 | 01:06 AM
PrettyLude's Avatar
check for a loose connection or possibly the sensor itself is bad
Old Mar 13, 2005 | 08:45 AM
dumpeDc2's Avatar
I'm a Jackass
Default Re: knock sensor (Ls_V_TurboSi)
if the sensor is bad you should consider chipping your ecu and haveing the knock removed
Old Mar 13, 2005 | 01:46 PM
hatch34's Avatar
where is the sensor at i have never really looked at one so im not sure what it looks like can someone tell me where it is at somewhat
Old Mar 13, 2005 | 01:48 PM
its to the left of the oil filter... Kind of a pain to get to.. theres 2 sensors or the back ones the oil pressure and the knock sensor.. the knock is above
Old Mar 13, 2005 | 01:56 PM
hatch34's Avatar
thanks for the info ill check it thanks
Old Mar 13, 2005 | 03:40 PM
hatch34's Avatar
Default Re: (PrettyLude)
also is there a way to test the sensor with out just buyin a new one
Old Mar 16, 2005 | 01:03 PM
troubledtech's Avatar
Default Re: (hatch34)
This is how I troubleshoot for a 98 civic.. http://redpepperracing.com/technical/143/aee
But you'll need a multimeter. It may work for your GSR, just the checking part. It maybe only comes on when the engine is on because that is when the Knock Sensor microphone detects the knock..meaning you might have a bad KS.
What year is your car? Maybe these manuals that I have used will help..
serrilion
May 17, 2011 09:26 AM
maomaniarocks
May 4, 2007 09:33 PM
shadykit
18
Mar 14, 2005 12:51 PM
lowexr
Jul 23, 2003 04:58 PM
SteelCityKid
Apr 16, 2002 10:32 AM
