Knock sensor Problem!!!
Does somebody know if a knock sensor can be tested anf if yes what is the procedure and if you have any schematic it would be easier
Re: Knock sensor Problem!!! (lowexr)
if u look in the manual the integra gsr it tells u how to check the knock sensor and see if its good or bad. most likey if your throwing a code for knock sensor its in teh wiring. i threw a knocxk sensor code for ever and was ready to change it out and everything turned out that i had my wiring pinned wrong on teh actual knock sensor on teh back of the block. remember it is a single pin plug.
Re: Knock sensor Problem!!! (thehatchninja)
hijacking this thread
if i get a new KS can i just wrap it i bubble wrap and leave it in the glove compartment or something?....wired up of course
