Help coil overs.?
Old Mar 12, 2005 | 10:11 AM
ekdriven's Avatar
Default Help coil overs.?
when trying to loosen these bolts what size is it? and they are pretty rusted and stuck on my car what can i do to help get them loose?
(not my picture, but hes loosening the same bolts.)
Old Mar 12, 2005 | 10:12 AM
Luserkid's Avatar
Default Re: Help coil overs.? (domgsr)
14mm and PB blaster and some elbow grease.
Old Mar 12, 2005 | 10:16 AM
EVIL Hx Coupe's Avatar
Grab a piece of pipe and put it to use... More leverage = loose bolt in no time.
Old Mar 12, 2005 | 10:38 AM
ekdriven's Avatar
well now i see that i need an extended 14 cause the sleeve doesnt cover the bolt all the way... i see this turning into alot of me gettin pissed off.
Old Mar 12, 2005 | 10:40 AM
carsaregood's Avatar
Default Re: (domgsr)
if you dont' have a deep socket 14mm handy, you can try using the box end of a combination wrench, and hitting it with a mallet. that should work
speedfreek128's Avatar
u need a deep 14mm......put some ***** into it and itll come off......or get ur buff sister
Old Mar 12, 2005 | 10:47 AM
ekdriven's Avatar
Default Re: Help coil overs.? (speedfreek128)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedfreek128 &raquo;</TD></TR><TR><TD CLASS="quote">......or get ur buff sister</TD></TR></TABLE>
haha.
but the 14 is like stripping the nut its on the so tight...
Old Mar 12, 2005 | 11:09 AM
Mario.'s Avatar
Holy **** dude, you haven't even gotten to the hard part yet.
Old Mar 12, 2005 | 11:15 AM
hondasport2000's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedfreek128 &raquo;</TD></TR><TR><TD CLASS="quote">u need a deep 14mm......put some ***** into it and itll come off......or get ur buff sister</TD></TR></TABLE>
Werd!
You could also spray the bolts with liquid wrench or something to help penetrate the rust.
Old Mar 12, 2005 | 11:20 AM
Tyree's Avatar
Default Re: Help coil overs.? (hondasport2000)
wait untill you get to the rear lca bolts
Old Mar 12, 2005 | 11:26 AM
Mario.'s Avatar
Default Re: Help coil overs.? (Tyree)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyree &raquo;</TD></TR><TR><TD CLASS="quote">wait untill you get to the rear lca bolts </TD></TR></TABLE>
w3rd.
EL SARGENTE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mario. &raquo;</TD></TR><TR><TD CLASS="quote">
w3rd. </TD></TR></TABLE>
that is exactly what i was gonna say
Old Mar 12, 2005 | 11:28 AM
komat's Avatar
haha i broke both of my
took me 10min to grid it off
spray pb blaster for couple of days b4 doing it!
also buy extra bolts just incase
or you will be carless
Old Mar 12, 2005 | 11:36 AM
Tyree's Avatar
Default Re: Help coil overs.? (komat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat &raquo;</TD></TR><TR><TD CLASS="quote">
or you will be carless</TD></TR></TABLE>
Exactly I broke mine off also.
Old Mar 12, 2005 | 11:42 AM
ekdriven's Avatar
wow this is sounding more and more fun...
i got soem PB blaster now was onyl using WD40 before.. tiem to drench that ****.
Old Mar 12, 2005 | 12:42 PM
airtools are your friend...
UserX826
10
Feb 21, 2009 10:02 PM
fallen87
Suspension & Brakes
Jan 30, 2009 11:50 AM
Tensa_Zangetsu
Dec 20, 2007 07:29 PM
_Cyclone_
10
May 16, 2005 01:15 PM
gowyeng
Jun 20, 2004 12:02 AM
