SC61, stock jdmb16+ shitty vacuum line= not good
Old Mar 11, 2005 | 01:13 PM
tthame1's Avatar
Default SC61, stock jdmb16+ shitty vacuum line= not good
Well i took the motor down after blowing it at IFO and this is what i found. All thanks to a piece of **** vacuum hose running from my wastegate to the turbo.
the amazing thing was that the only thing that broke were the sleeves, the pistons were fine and the rods etc..... It hit no telling how much boost right off the line and it blew about 100 ft. before half track. No detonation on the pistons and the head was fine, its on a b17 bottom i got and running perfect right now.
Old Mar 11, 2005 | 01:15 PM
getnasty's Avatar
Default Re: SC61, stock jdmb16+ shitty vacuum line= not good (tthame1)
melted didnt it? where to find one that dosent melt? any type of covering? I was thinking some braided wire. maybe like a oil line
Old Mar 11, 2005 | 01:20 PM
tthame1's Avatar
Default Re: SC61, stock jdmb16+ shitty vacuum line= not good (bottle fed)
No it didnt melt anything, like i said all that happened was the sleeves cracking. Cylinder #2 was cracked too but its not pictured.
Old Mar 11, 2005 | 01:21 PM
splitime's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tthame1 &raquo;</TD></TR><TR><TD CLASS="quote">No it didnt melt anything, like i said all that happened was the sleeves cracking. Cylinder #2 was cracked too but its not pictured.</TD></TR></TABLE>
Think he was asking about your vac line.
Old Mar 11, 2005 | 01:32 PM
tthame1's Avatar
Default Re: SC61, stock jdmb16+ shitty vacuum line= not good (splitime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime &raquo;</TD></TR><TR><TD CLASS="quote">
Think he was asking about your vac line.</TD></TR></TABLE>
:doh: its been a long day. The hose split and just broke in half almost.
Old Mar 11, 2005 | 01:38 PM
RobbieG35's Avatar
12 Years Strong
:doh: its been a long day. The hose split and just broke in half almost.</TD></TR></TABLE>
Man this makes me want to invest in the steel braided lines Fast-Turbo sells
Old Mar 11, 2005 | 01:56 PM
tthame1's Avatar
Default Re: SC61, stock jdmb16+ shitty vacuum line= not good (HybridHatch88)
Its my own fault, it was just regular silicon hose, if you use fuel line it will be okay
Old Mar 11, 2005 | 07:33 PM
tony n.'s Avatar
were you the one drivin the red coupe? runnin on the right lane? what happen? damn maybe u can make it to the one in shreveport
Old Mar 11, 2005 | 07:41 PM
mrbsponge's Avatar
damn that thing almost split the whole way down
Old Mar 11, 2005 | 07:42 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (mrbsponge)
that sucks. I bet it felt hella fast before it popped tho, lol
Old Mar 12, 2005 | 09:28 AM
DRIVENRacing's Avatar
thats crazy...usually a rod or a piston goes before the sleve does... if tuned right, stock sleves are pretty strong
Old Mar 12, 2005 | 09:30 AM
TA Performance's Avatar
so running the vacuum line from turbo to wastegate isnt a good idea??? then is it better to run it to the intake manifold???
Old Mar 12, 2005 | 09:58 AM
Flr Power's Avatar
Running a max boost cut enabled in the software would have saved the engine since the reading is taken at the map sensor itself.
Old Mar 12, 2005 | 10:10 AM
StockBlockRob's Avatar
Default Re: (Flr Power)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flr Power &raquo;</TD></TR><TR><TD CLASS="quote">Running a max boost cut enabled in the software would have saved the engine since the reading is taken at the map sensor itself.</TD></TR></TABLE>
good call
Old Mar 12, 2005 | 10:16 AM
ScottEK's Avatar
Default Re: (Boro_DC2)
No you just run a good vacuum line or silicone line and secure it properly.
Old Mar 12, 2005 | 11:55 AM
m R g S r's Avatar
That's why I have a re-inforced high pressure fuel line going from the turbo to the gate. . .
3900 posts...wOot woOt
Old Mar 12, 2005 | 10:39 PM
turtle-eg's Avatar
Actually, I have seen two cars with hondata that hit boost cut and blew their motors.... one of them being me, also cracked, well actually blew a 2x2" hole in the sleeves.
Old Mar 12, 2005 | 11:44 PM
SHystrdyGSRtdy's Avatar
Default Re: SC61, stock jdmb16+ shitty vacuum line= not good (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">
(cutout)...wOot woOt </TD></TR></TABLE>
better edit your post.. if an **** mod sees that.. they'll reset it
Old Mar 12, 2005 | 11:45 PM
Default Re: (turtle-eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turtle-eg &raquo;</TD></TR><TR><TD CLASS="quote">
Actually, I have seen two cars with hondata that hit boost cut and blew their motors.... one of them being me, also cracked, well actually blew a 2x2" hole in the sleeves. </TD></TR></TABLE>
so what's your solution? just use better lines? i probably will use a SS line.. i have a lot.. but they're really long (bought a few oil feed lines)
GForceInteg
Jun 6, 2005 01:19 AM
mitsuman
Apr 11, 2004 03:32 PM
dualknuttz1
Aug 10, 2003 10:34 PM
ion_four
Jun 24, 2003 08:11 AM
