Wiring issures with 95 gsr swap into a 99 ex
Is there any way to on obd1 engine obd2 so that it will pass emissions, suck as changing out sensors from one to the other. I was origionally just going to use the conversion harness, but will that pass?
the harness will not help pass emissions on an obd2 car. all they do is plug up the test and see if u have any check engine lights... u would need to run the crank angle sensor(obd2 oil pump) and another o2 sensor and just run the stock EX ecu during the test. i know im forgeting something else......ill remember the rest later.
I was going to run a gsr ecu, I know I could use my wire harness and get an adapter but then I wouldn't even link up to search for codes. I was just wondering if I could convert those things like you said and run the obd2 ecu.
TIPSY-99civic
16
Jul 11, 2012 05:57 PM
williebrenn
Aug 13, 2008 03:44 PM
1zach4
Jul 19, 2007 04:04 PM
iheartmyej8
Feb 11, 2007 06:30 PM
