another noob question: D15b sohc vtec vs ZC dohc
here comes another war. so many people have so many different opinions most the timeits more of what u like best.
Oh and search next time. Its amazing the things you find.
Here is many topics on what u asked.
https://honda-tech.com/zerosearch
The search feature is your friend.....
I found these threads in 2 minutes of searching recent and archived content
d15b vs sohc zc
https://honda-tech.com/zerothread?id=1149815
sohc vs. dohc
https://honda-tech.com/zerothread?id=1106364
sohc d15b vs dohc zc
https://honda-tech.com/zerothread?id=1106043
sohc d15b vs. dohc zc
https://honda-tech.com/zerothread?id=960203
d15b vs sohc zc
sohc vs. dohc
Alright, I look look around later when I have more time. I guess probably a lot of the questions I have have already probably been discussed to death on here
Only a few things I want to confirm:
The ZC is a little more torquey?
The ZC is obd-0 since it came in the same years as the EFs right?
Would I still need to to the DPFI --> MPFI conversion?
The ZC has more torque.
The ZC is OBD0 but it did come in a 92 hatch and it was OBD1 but the majority of ZC's are OBD0
If you have a std or dx model civic/crx you will need to convert from dpfi to mpfi
will the d15b vtec bolt up to the cable trans on an 89 crx si?
and will the stock d15b mounts bolt up to the 89 crx engine mounting points?
what ecu do you have to run to make it work?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thrty8street »</TD></TR><TR><TD CLASS="quote">will the d15b vtec bolt up to the cable trans on an 89 crx si?
what ecu do you have to run to make it work?</TD></TR></TABLE>
3000+ posts and you don't know how to search?
1. Yes
2. Yes
3. P28 or P08
1. Yes
2. Yes
3. P28 or P08
Go Obd1 shoc zc vtec....
i smoked a h22 prelude on mine
with full interior and a box and headers which only gave me like 2hp...lol
SoullessJapaneseMachine
27
Dec 4, 2006 06:46 PM
