who's using datalog... NO HONDATA!
Old Mar 9, 2005 | 05:34 PM
JDMlyfestyle's Avatar
Default who's using datalog... NO HONDATA!
i was just wondering who out there is using datalogging.
ECUcontrol
Uberdata
Ghettodyne
Ect.
If so do you have to burn the chip to enable datalogging? or will it datalog automatically?
Old Mar 9, 2005 | 06:09 PM
DOHCtorTHRUST's Avatar
Default Re: who's using datalog... NO HONDATA! (JDMlyfestyle)
i believe it will datalog with the program(ie. uberdata/crome) however you would want to make adjustments(via tunning) through a Real Time Programer(rtp) with a emulator instead of burning a new chip after everytime you make a adjustment.
Modified by DOHCtorTHRUST at 3:26 AM 3/10/2005
Old Mar 9, 2005 | 06:56 PM
well i got a shitload of chips but i cant get my datalog to work. For some reason the ECUcontrol software wont log
Old Mar 9, 2005 | 07:20 PM
boosted k20's Avatar
Default Re: (JDMlyfestyle)
im using datalogging with UBERDATA. uberdata1.7 and uberdata1.8 (this version doesnt work for me. i keep get n constant CEL) Uberdata1.7 works flawlessly for me. i use it in my car and in all the cars i build for uberdata.
to run datalogging with uberdata or basically any other system, u will need to first add a dataloggin cable into the ecu. once u do this, u must have a version of the program that u r using that has datalogging built into it. Uberdata1.66 does not have datalogging enabled so u will need uberdata1.7. once u have a chip burnt with uber1.7 u can start to datalog.
and u dont really need realtime programming. it's just *bling bling* to make tune n go a little faster. i dont use it even though it would be cool to have,. i'll keep it simple and just burn a chip everytime i make changes
Old Mar 9, 2005 | 07:21 PM
Default Re: (boosted k20)
alos if ur using the USB cable, u will need to download the USB driver for it. here it is on this webpage http://www.pgmfi.org/twiki/bin...Tools
Old Mar 9, 2005 | 08:03 PM
already had that. but for some reason the ECU control software doesnt detect it. non of the gauges on the software work in live. i clicked start datalog and i drove for around 35 mins. and i didnt get any info back
Old Mar 10, 2005 | 05:22 AM
what r u using? CROME, UBERDATA???
Old Mar 10, 2005 | 06:35 AM
mmuller's Avatar
Mad Scientist
what datalogging board are you using? baud rates and such?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted k20 &raquo;</TD></TR><TR><TD CLASS="quote">what r u using? CROME, UBERDATA???</TD></TR></TABLE>
edit: look at this for troubleshooting:
http://www.pgmfi.org/twiki/bin...gging
Old Mar 10, 2005 | 06:59 AM
blundar's Avatar
just out of curiousity...
You have a board dedicated to engine management, yet you ask the lunatic masses of h-t these questions instead of using it.
Why?
ECUControl (And Uberdata, Crome and Freelog) all require an "aftermarket" serial ISR. In Crome, you use this by installing the Datalogger+ tool. In Uberdata, it's automatically compiled into the ROM. You may also want the check the state of J12 based on which code implementation is in the ROM.
rick_rabies
Engine Management and Tuning
15
Aug 20, 2009 09:41 AM
Turbo-Honda
May 19, 2005 10:35 PM
DC2R714
Apr 6, 2004 01:11 PM
UnderPressure
Apr 24, 2002 07:35 AM
OneThirtyEight
Nov 2, 2001 06:10 PM
