installing water temp gauge
Old Mar 8, 2005 | 06:04 AM
superchargedex's Avatar
Default installing water temp gauge
iam trying to install my water temp gauge but the sending unit wont fit in my water pump with out hitting the thermostat. does anyone know where a good place is to put it or will i have to get a electrical water temp gauge? thanks
Old Mar 8, 2005 | 04:15 PM
boostmywankle's Avatar
Default Re: installing water temp gauge (superchargedex)
i heard if u put a T inline with the upper radiator hose..then skrew the snesor into the t and call it a day
Old Mar 8, 2005 | 04:31 PM
Synth124's Avatar
Default Re: installing water temp gauge (96teggyls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96teggyls &raquo;</TD></TR><TR><TD CLASS="quote">i heard if u put a T inline with the upper radiator hose..then skrew the snesor into the t and call it a day</TD></TR></TABLE>
Old Mar 8, 2005 | 05:21 PM
RCautoworks's Avatar
I actually used one of the hoses from the eacv, just did a little rerouting. Works great, if I can find pics I'll post them up.
Old Mar 8, 2005 | 05:22 PM
Old Mar 9, 2005 | 08:00 PM
my sending unit is mechanical not electrical so the sending unit is about 2 inches long and about the width of a pen so the t wont work do u have any other ideas?
Old Mar 9, 2005 | 08:24 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superchargedex &raquo;</TD></TR><TR><TD CLASS="quote">my sending unit is mechanical not electrical so the sending unit is about 2 inches long and about the width of a pen so the t wont work do u have any other ideas?</TD></TR></TABLE>
Um mine was that long to, so was a customers and they way worked perfect.
Old Mar 9, 2005 | 09:23 PM
Default Re: installing water temp gauge (90blackcrx)
so where did u put it i have a 2000 civic ex what kind of car do you have
Old Mar 10, 2005 | 09:20 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superchargedex &raquo;</TD></TR><TR><TD CLASS="quote">so where did u put it i have a 2000 civic ex what kind of car do you have
I stated it above, between the eacv hoses. I have a crx, but coolant hoses are coolant hoses. Go to your local parts stock ( not an autozone or pepboys ) or local store where 1 guy owns it, and tell him what your doing and he will set you up with the fittings. Your gonna need one way fittings ( barb fittings ) to slip the hoses onto.
Old Mar 10, 2005 | 12:53 PM
just curious how long is your sending unit
Old Mar 10, 2005 | 12:57 PM
CRX Toad's Avatar
Just so you know your in the CRX/EF forum not the EG/EK forum. But 90blackcrx
has it handled for you
Old Mar 10, 2005 | 01:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superchargedex &raquo;</TD></TR><TR><TD CLASS="quote">just curious how long is your sending unit</TD></TR></TABLE>
Are you actually reading what I type, because I already explained mine was the same length. It was about 2 inches, get a t fitting and thread it in there.
See the long sending unit in the pic, thats the one I used. Yours might be a tad different, but if you use the same concept I posted, you will be fine.
alexb16hb
Jul 5, 2006 08:05 PM
mike93eh
Mar 20, 2005 09:35 PM
The G2 Racer
Apr 20, 2004 04:22 PM
turbohf
Jan 27, 2003 10:06 AM
speedymon
Aug 28, 2002 01:16 PM
