Got the oil feed lines done but the sensor will not tighten all the way???????? SEARCHED
Old Mar 6, 2005 | 09:45 PM
dan_w_82's Avatar
Default Got the oil feed lines done but the sensor will not tighten all the way???????? SEARCHED
I finished up the install on my oil lines and the oil pressure switch is in a tight spot that I can't get to with ANY tool to tighten. I hand tightened it the best I could but just want to get some ideas if this will be alright.
I also searched and seen that people don't even use the sensors. If this is not good enough could I just block it off and then next month get a oil pressure gauge and then have a true reading instead of a dummy light that is always to late. Thanks
Old Mar 6, 2005 | 09:52 PM
SHystrdyGSRtdy's Avatar
Default Re: Got the oil feed lines done but the sensor will not tighten all the way???????? SEARCHED (dan_w_
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dan_w_82 &raquo;</TD></TR><TR><TD CLASS="quote">I finished up the install on my oil lines and the oil pressure switch is in a tight spot that I can't get to with ANY tool to tighten. I hand tightened it the best I could but just want to get some ideas if this will be alright.
I also searched and seen that people don't even use the sensors. If this is not good enough could I just block it off and then next month get a oil pressure gauge and then have a true reading instead of a dummy light that is always to late. Thanks </TD></TR></TABLE>
how much do you want for it shipped? what condition is it in? pics?
*this is classifieds.. wrong forum*
Old Mar 6, 2005 | 10:16 PM
dan_w_82's Avatar
Damn I was in a search and got confused. MODS please move thanks
Old Mar 6, 2005 | 10:20 PM
dan_w_82's Avatar
NOTE TO MODS DELETE THIS THREAD I copied and pasted into the forced induction section.
Sorry and thanks
velisma
Jan 30, 2010 08:24 PM
twentyhurtz
Dec 7, 2008 09:17 AM
SpoolinMotors
Dec 7, 2006 08:07 AM
pelotudo
Aug 18, 2002 06:31 PM
