Header won't bolt up to magnaflow cat. help!
Old Mar 1, 2005 | 03:15 PM
xmr. robotox's Avatar
Default Header won't bolt up to magnaflow cat. help!
here is my exhaust setup uninstalled:
kamikaze header with 2.5" downpipe, magnaflow 2.5" cat, 2.5" kteller bolt up exhaust piping, and magnaflow muffler.
So I went to the exhaust shop today to have it all installed and the problem we ran into was the down pipe from the header doesnt hook up to the cat. To me it looks like the way kamikaze made the down pipe is the reason why it wont work. does anyone know of a header that will hook up to a 2.5" magnaflow cat? Is there any other headers with 2.5" downpipes? this really sucks. any help would be appreciated.
Old Mar 1, 2005 | 03:20 PM
Terrible One's Avatar
Default Re: Header won't bolt up to magnaflow cat. help! (Civiapt)
what car and what motor?
Old Mar 1, 2005 | 03:21 PM
Default Re: Header won't bolt up to magnaflow cat. help! (orig1nalkhmersta)
it is a 98 civic d16y8
Old Mar 1, 2005 | 03:23 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civiapt &raquo;</TD></TR><TR><TD CLASS="quote">So I went to the exhaust shop today to have it all installed and the problem we ran into was the down pipe from the header doesnt hook up to the cat. To me it looks like the way kamikaze made the down pipe is the reason why it wont work.</TD></TR></TABLE>
Can you elaborate on the actual problem you're experiencing, and why it "doesn't hook up"? A competent muffler shop shouldn't have any problems connecting the header to the cat.
Old Mar 1, 2005 | 03:28 PM
Default Re: Header won't bolt up to magnaflow cat. help! (Padawan)
lets see...how can I explain...
well, at the end of the downpipe there is the flange and then it has about 1 more inch of piping. so when I go to hook the exhaust pipe with the downpipe they cant slide together because of the rest of the downpipe. so there is about an inch inbetween the flanges. hope this makes sense.
Old Mar 1, 2005 | 03:32 PM
maybe I should take it to another shop and have them look at it?
plus I really don't want to have to sell this header and get a different one. i dunno. anymore help? thanks
Old Mar 1, 2005 | 03:33 PM
dantastic's Avatar
sounds like you can use longer bolts.... there is about 1" between the flanges of a oem cat and header. maybe you need a gasket btwn the header and the cat??
Old Mar 1, 2005 | 03:34 PM
Default Re: Header won't bolt up to magnaflow cat. help! (dantastic)
maybe there isn't anything wrong with it and the exhaust guys were just dumb?
^the only thing I see is the cat is like "flared" out at the ends and the downpipe is just strait. wouldn't it leak?
Old Mar 1, 2005 | 03:36 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civiapt &raquo;</TD></TR><TR><TD CLASS="quote">lets see...how can I explain...
well, at the end of the downpipe there is the flange and then it has about 1 more inch of piping. so when I go to hook the exhaust pipe with the downpipe they cant slide together because of the rest of the downpipe. so there is about an inch inbetween the flanges. hope this makes sense. </TD></TR></TABLE>
What you're describing sounds like a typical donut "flex joint" -- the same type of joint found on the stock manifold and all bolt-on replacement Honda headers. You are supposed to install a graphite donut gasket over the end of the collector, and your cat should have a flared flange that can bolt to the header.
Old Mar 1, 2005 | 03:40 PM
so basically, that 1'' space should have a graphite donut gasket and then I would need longer bolts? because the end of the cat is flared out. do I need to buy a graphite donut gasket separet? or would I just use the stock one?
Old Mar 1, 2005 | 03:43 PM
RangerDan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">
What you're describing sounds like a typical donut "flex joint" -- the same type of joint found on the stock manifold and all bolt-on replacement Honda headers. You are supposed to install a graphite donut gasket over the end of the collector, and your cat should have a flared flange that can bolt to the header.</TD></TR></TABLE>
Yeah...I think you got it there. Ive been to some muffler shops that dont carry the size you will need....so figure out which donut you need then go buy it before you head back to another muff shop.
Old Mar 1, 2005 | 03:44 PM
Default Re: Header won't bolt up to magnaflow cat. help! (RangerDan)
were could I get one of these graphite donut gasket ?
Ghetto Civic HX's Avatar
I love to drive
I don't think your stock one will work because it isn't 2.5". You'll have to buy a new one, but they aren't that expensive, like under $10 at a parts store.
Old Mar 1, 2005 | 03:45 PM
Default Re: Header won't bolt up to magnaflow cat. help! (Ghetto Civic HX)
would the stock one fit the 2.5" downpipe?
Old Mar 1, 2005 | 03:47 PM
I love to drive
I edited my other post. Your stock one won't fit. It's too small.
Old Mar 1, 2005 | 03:54 PM
I figured out how to host a picture.... This is what it looks like if my explaination didn't make sense at all..
Old Mar 1, 2005 | 03:57 PM
I also have another question... Is my header going to be able to bolt up with the stock gasket?
Old Mar 1, 2005 | 04:00 PM
dantastic's Avatar
looks like you need to flare the end of the cat facing the header, get a "donut" gasket for a JDM 2.5" header, and get some longer bolts
you can probably re-use ur header gasket at the head. you can find the 2.5" gasket at those JDM stores like jhpusa.com
Old Mar 1, 2005 | 04:03 PM
Default Re: (dantastic)
but the cat is flared isn't it? (the one on the left) the downpipe is the one on the right and the flange is welded in place. the one on the cat isnt.
Old Mar 1, 2005 | 04:15 PM
Default Re: (Civiapt)
http://www.jhpusa.com/catalog/...95990
^is this what I would need? do you think maybe autozone or somewhere might have these?
Old Mar 1, 2005 | 04:54 PM
bump?
Old Mar 1, 2005 | 05:03 PM
8krdline's Avatar
honda will have them, but they are still 20some bucks. get one from a s2000 or a legend?(I've read that will work)
Old Mar 13, 2005 | 09:32 PM
SMSP's Avatar
Did you get the header with the 2-1/2" collector or the usdm 2"?
ANyway, for whatever reason, Kamikaze has way too much tubing sticking past the flange, even with a donut it won't work. You must cut the tubing shorter, about 5/8" should go past the end of the flange, then the donut will work.
bubbakush
Feb 26, 2004 09:45 PM
blykins
Feb 22, 2004 12:47 PM
Nader_D
10
Nov 19, 2003 10:02 AM
TSAngry
Nov 5, 2002 05:35 PM
