need some help k people
Old Mar 1, 2005 | 08:48 AM
josh green's Avatar
Default need some help k people
I have my a2 into my eg hatch and I was driving it around saturday night and I drive it to school yesterday. Right after school i went to the muffler shop to get the to connect my header and the current exhaust. Then when I leave the shop the car is rev limiting itself at 4k. Well I drive it throught town to get home and then the tach needle starts jumping from 0-3k and all in between. I am driving up this hill and it dies, well i recrank it while its rolling and try to get it over the hill and I eventualy do. Well I coast it in a parking lot and pop the hood. I check all my fuel and vaccum lines and everything is fine. I check my wiring in the car and its all fine and the same as it was when it was running fine, nothing had come undone. Well i see how long it will idle before it will do the needle hoping and die. Well it does and not too long after I had cranked it. Well I pulled the battery terminal and waited and rehooked it. Well it started idling fine and I figured it was just wanting gas b/c I was low. SO I drive it to the gas station and its fine, I never got it over 4k so I didnt know if it would still limit it or not. Well I put like $3 in gas and not i have 1/4 tank and I figure that enough for me to get to walmart where I have a gas card. Well I come back from paying and it wont start. It turns over but it dont fire. I push it to the curb and I check the grounds and whatnot and my main relay is working but the fuel pump wont cut on. Well after tampering around and turning the switch on and off I can the pump to cut on. The fuel pump will cut on when I touch the 2 grounds together and eventualy would work when i bolted them back down. Well it still wouldnt start and me and some friends are out there try to find out whats wrong and the fuel pump stops kicking on. We check to see if there is 12v going to it and there is but the pump wont come on. There is a possibility that it may not be sparking so I have no clue how to check ignition on the k series. So as of now its on the trailer and hooked to the back of my truck and I am dragging it around b/c I couldnt get it off by myself lastnight and didnt have time this morning.
Any suggestions? I have typed everything in the exact sequence it started doing everything.
also i have hybrid racing harness and K pro
Old Mar 1, 2005 | 09:04 AM
Nikos's Avatar
Default Re: need some help k people (josh green)
Of you have more than one problem here.
Just call hybrid racing and they will walk you through this.
Having read a lot of people's questions... one thing that is messed up is your grounds.
Another problem you seem to have is the 4k rev limit... There are a few reasons why this would happen. For example if the ecu doesn;t read water temp, it protects the engine by not letting you rev more than that.. Also maybe your k pro is setup wrong...
I would start by figuring out the starting/grounding problem first.
Give them a call since you bought their harness. That same issue has happened in a few cars. They will walk you through.
Old Mar 1, 2005 | 10:43 AM
josh green's Avatar
well yersterday I got an O2 bung put in my echaust so that I could put in the 2nd O2. I have the temp sensor on a water line and its wired up according to how I was told from hybrid and it dosent work, but I have heard that I am not the only one that has had this problem.
josh green's Avatar
all these delays are pissing me off.
Old Mar 1, 2005 | 10:55 AM
Nikos's Avatar
Default Re: (josh green)
Ok, so you are not getting H20 temp.
I would run a direct wire to HARNESS PLUG C302 PIN 10 to the sensor.
Old Mar 1, 2005 | 02:35 PM
aspec04t's Avatar
Default Re: (Nikos)
seems like ur car is running in limbo mode
5speeder
Mar 20, 2012 03:47 PM
01DC4
Honda S2000
Apr 19, 2008 03:09 PM
billabongkid13
Jan 25, 2008 05:18 AM
josh green
Mar 1, 2005 09:00 AM
josh green
Mar 1, 2005 08:22 AM
