I need advice of what turbo I need for my setup?
Old Feb 24, 2005 | 05:43 PM
booscivic's Avatar
Default I need advice of what turbo I need for my setup?
First off I have searched, but I cant read compressor maps. I need to match what turbo I need for my set up. Right now I have turbonetics t3/tO4e 57 trim 63a/r stage III. This turbo is really laggy on my car, I was thinking of switching to a 48a/r to get a faster spool on a more usable rpm range or switch turbos. What is your opinion should I switch exhaust housing or turbo and what turbo do you guys recommend? Thanks for all you help and opinios> PS Im reving to 8k HP goal is 350 but more power is alwasy welcome.
Set up:
d16z6
BOTTOM:
wiseco.20overbore /scat rods 8.8.1 compression
GE blockguard
arp bolts everywhere/fully balance and blueprinted
HEAD:
zex/comp
cam/sprocket
stock valves and comp spring retainers
edelbrock Intake manifold
FUEL:
fuel RC 550
AEM fpr
BBK 255 fuel pump
hondata S100b
AVCR
all kind of guages oil/boost/tach/egt
TURBO:
boost cooler methanol injection kit
Tial w/g
revhard manifold
greddy type s
street import hughe intercooler
2.5 dp flared to 3"
Modified by booscivic at 4:27 PM 2/27/2005
Old Feb 24, 2005 | 05:57 PM
MooreBoost's Avatar
Default Re: I need advice of what turbo I need for my setup? (booscivic)
I was told my .48 would fall off on the top end while shooting for 350, and to switch to a .63.
How about running a 55 shot on it to spool the turbo? I might do that.
Old Feb 24, 2005 | 06:07 PM
booscivic's Avatar
I dont really want to do nitrous, I was told this turbo can support 500,if thats true then 350 is should be no porblen and the compressor 60a/r is big for higher rpm range
Old Feb 24, 2005 | 06:23 PM
Benjithx's Avatar
Default Re: (booscivic)
trade me for my BB turbonetics t3t04b it spools very quickly and you could push it to 300
Old Feb 24, 2005 | 07:03 PM
Maveric's Avatar
check out http://www.phoenixturbo.com talk to ken he can switch you out to a .48 ar which will spool much faster and give a much more usable powerband ...especially for you d-series
Old Feb 25, 2005 | 06:36 AM
booscivic's Avatar
Default Re: I need advice of what turbo I need for my setup? (maveric)
Thanks anybody else?
Old Feb 25, 2005 | 06:45 AM
Rod Short's Avatar
The least expensive thing would to just switch out the turbine housing. Much less expensive than going ball bearing.
I've got a.48 A/R on my 2.3L (that's the factory set up) and it comes on like a light switch, but I'm not making the power you are.
Just be sure it's machined specifically for that wheel.
Rod Short
Sales Manager
Precision Turbo
Old Feb 25, 2005 | 06:49 AM
DaX's Avatar
DaX
Loved
Community Favorite
When will the .48 turbine housing reach it's limit? It's what I've got on my turbo LS...I do love the response.
Old Feb 25, 2005 | 07:07 AM
platinum00's Avatar
Default Re: (DaX)
call presision, they will size your turbo for you for free.
this is what i did.
platinum.
Old Feb 25, 2005 | 08:15 AM
booscivic's Avatar
Default Re: I need advice of what turbo I need for my setup? (Rod Short)
Thanks for your help
Old Feb 27, 2005 | 09:07 AM
booscivic's Avatar
Default Re: (platinum00)
Thanks
alpha's Avatar
Accidently deleted my last reply
If you are not ready to purchase a turbocharger I would follow Rod Short's advice. If you are talk to a Garrett/Precision dealer, Arturbo/ForcedAir/Flamenco-T/TheShodan/Full-Race Motorsports/SPARK RACING INC./This One/Tinker219 and others, and they will be able to properly size a turbocharger for you.
We (Trip, Blown90Hatch and I) are going to be testing a GT3255E on a Wiseco/Eagle D16 here soon. I will let you know how it goes when I can
Old Feb 27, 2005 | 09:14 AM
booscivic's Avatar
Default Re: I need advice of what turbo I need for my setup? (0x64)
Actuall, I have a buyer for my turbo. I need to decide what turbo to go with?
Sofakingtyte
May 15, 2008 05:26 AM
B18T3T4
Oct 30, 2006 11:30 AM
booscivic
Mar 7, 2005 02:35 AM
BoOsTiN Dc2
Sep 11, 2004 07:49 AM
boost killz
Jan 13, 2002 09:06 PM
