Anyone have; stock ls gt28rs(disco)? want to know if i will like.
Old Feb 23, 2005 | 07:07 PM
EF'n's Avatar
Default Anyone have; stock ls gt28rs(disco)? want to know if i will like.
Just wondering if anyone has the setup that I am building. It will be a stock jdm b18b with mini-me and gt28rs. Not sure what injectors i will run yet, but we are going to use hondata, 3" exhaust, and less then 10psi. If you have a similar set up please give me feed back on your thoughts. thanx guys.
Old Feb 23, 2005 | 07:50 PM
HiProfile's Avatar
Default Re: Anyone have; stock ls gt28rs(disco)? want to know if i will like. (LoveFabMotorsports)
A redlined B18B welcomes 21 lbs/min of air, and at ~10 psi, thats almost smack-dab in the middle of the 77% 'bubble' on the gt28rs's corrected airflow chart. It equals a max efficiency of 79% for the gt28rs and 77% for the gt28r (guessing since it falls right in the middle on the lines for both).
In layman terms, a great turbo if you ever plan to boost a bit more w/higher redline. I'm in the same boat, but since the LS has the lower torque already, I'm going with the RS. If nothing else, buy a cheap T25 for testing - same boltup as the gt28rs, compressor outlet is slightly different. If you like quick spool & the midrange it gives you, get the gt28r (and sell the t25 for what you bought it for). If its a street/strip car, get the RS.
Old Feb 23, 2005 | 07:55 PM
EF'n's Avatar
Default Re: Anyone have; stock ls gt28rs(disco)? want to know if i will like. (HiProfile)
Well my goals are pretty low, just want a clean looking fast street car. Looking for about 200 whp, and keep it drivable. I have heard really good things about the gt28rs, just wanted to make sure it is a good match up for my goals. (quick spool)
Old Feb 23, 2005 | 08:04 PM
hybridsol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LoveFabMotorsports &raquo;</TD></TR><TR><TD CLASS="quote"> Looking for about 200 whp, and keep it drivable. </TD></TR></TABLE>
Ha! I think you could make 200 WHp at about 6 psi with that turbo.
I have the larger 3071 w/ .48 A/R, it spools in an instant above 3500. The GT28 will spool even faster.
No worries there!
Old Feb 23, 2005 | 08:35 PM
integrx's Avatar
New User
Don't know if you have seen this before yet. Although its not a LS but its still a gt28rs on an Honda/Acura. http://www.atpturbo.com/root/t...r.htm
Old Feb 23, 2005 | 11:12 PM
Tchleung's Avatar
Default Re: Anyone have; stock ls gt28rs(disco)? want to know if i will like. (integrx)
oh man I didn't realize they dyno tested the gt28RS on a b17. damn taht's EXACYTLY what I wanted tos ee lol. What' the standard inelt size of the GT28RS? 2.75"?
Old Feb 24, 2005 | 02:38 AM
EF'n's Avatar
Default Re: Anyone have; stock ls gt28rs(disco)? want to know if i will like. (Tchleung)
Sounds like the gt28rs is the snail for me. Would be nice to find someone with a b18b/a with the disco on it to ring in.
moncrease
Mar 7, 2008 03:32 AM
Jtuned DC2
Feb 7, 2008 10:33 AM
six7one
Apr 11, 2005 03:53 AM
94b18b1
Jul 8, 2003 01:58 PM
VoltageLS
Apr 7, 2002 01:40 PM
