problem w/ b20 start-up
Old Feb 22, 2005 | 06:00 PM
integrasaurus-rex's Avatar
Default problem w/ b20 start-up
recently swapped a b20 into my integ the other day and now it wont start. Today when it started it sounded like a grinding noise when the starter turned; I turned it off and tryed to start it again. The second attempt to start it didnt even turn the starter, any ideas? This is BS..... @$*& #%#@ $^%$Y T%$@^ $%@$%$ @#!!!!!!
Any good mechanics in the socal 818 area?
Old Feb 22, 2005 | 08:59 PM
PrettyLude's Avatar
bad starter?
Old Feb 23, 2005 | 12:51 AM
ntgr8td's Avatar
Default Re: (PrettyLude)
can you be a little more specific about the grinding noise? did it sound like a starter? did you change the timing belt or any scary stuff like that? did you use the stock b20 manifold or did you convert? details please. the little stuff is usually the prob
Old Mar 8, 2005 | 11:54 PM
Default Re: (ntgr8td)
Sorry took so long to get back guys got some other issues goin on. Well its a b20 block b18 head everything is machined and built by a shop. The grinding noise i believe sounds like the starter because when the car is started you can't hear the noise. Now the damn car just clicks when I try to start it? %^#$^!!!!! I'm pretty sure it's the starter what do you guys think? You guys know your %^*^!!
Pics coming soon....
Old Mar 9, 2005 | 06:32 AM
PrettyLude's Avatar
check ur battery first man, you are not supposed to hear your starter after the car is started, that's because its job is to only get the car started
Old Mar 9, 2005 | 07:22 AM
93turbo16's Avatar
yep, check the battery first, and the connections. Then you can actually take the starter apart and rebuild it if you want to. Its pretty easy to do. Then you can test it outside the car by hooking it up to a battery charger and jumping the switched power and the constant power.
Old Mar 9, 2005 | 05:53 PM
Default Re: (93turbo16)
connections are cool so i guess the only thing left to do is to take it off and try to rebuild it? So i dont actually need to go to Acura and buy a new starter?
just rebuild....
Old Mar 9, 2005 | 09:10 PM
PrettyLude's Avatar
bring it to autozone and let them test it out first to see if it is bad
Old Mar 11, 2005 | 11:52 PM
thanks all
i'll get back when i fig it out
bumps to all
Old Mar 23, 2005 | 12:40 AM
Default Re: (integrasaurus-rex)
yes, thanx to all ht members i got it running after the swap. and that thing kicks ***!!!!!!!!!!!!!!!!!!!!!!!!
flybikes757
Feb 16, 2013 10:50 AM
himhimself
15
Aug 20, 2009 03:32 PM
rwlangdale
Feb 12, 2008 08:12 AM
420hAtCh
Oct 30, 2007 02:14 AM
rasinhell
13
May 25, 2005 11:57 AM
