Moroso oil pan with oil retun
Old Feb 19, 2005 | 03:53 PM
B18c1turboedEK's Avatar
Default Moroso oil pan with oil retun
I am running a moroso oil pan and am having trouble to get the oil return line, to work correctly!!
Someone told me too use the bottom hole instead of the top right one,
Is this correct??
I have tryed to use ever fitting i can and i can get it too have a slope. I dont wanna remove the pan to get another bung welded any IDeas??
this pan is the one with the 2 bungs on the front!!!
Thanks
Old Feb 19, 2005 | 03:54 PM
Default Re: Moroso oil pan with oil retun (B18c1turboedEg)
And i have searched!!!!
Old Feb 19, 2005 | 03:56 PM
PrettyLude's Avatar
pictures please. i think the bottom hole you are trying to use will not work, it might cause the oil to back up in the line
Old Feb 19, 2005 | 04:12 PM
Default Re: (PrettyLude)
Old Feb 19, 2005 | 04:19 PM
Rain_man's Avatar
New User
What do you mean it's not working? Is it not draining?
Most setups on HT try to have their return as high up as possible so that oil can drain as easily as possible. I've heard some people say that they have theirs low to minimize foaming but I don't see how the oil can drain if it's low in the pan.
Old Feb 19, 2005 | 04:27 PM
Default Re: Moroso oil pan with oil retun (Rain_man)
I mean i cant get the return line to work becasue its hitting the piping.
What do you guys use to make it work???
Old Feb 19, 2005 | 04:28 PM
silver89civic's Avatar
if the oil isn't drained properly, the oil is gona stay in your turbo.
Old Feb 19, 2005 | 04:29 PM
igo4bmx's Avatar
what piping is it hitting?
you can get really short 90 an fitings that may do the trick for the top right hole.
Old Feb 19, 2005 | 07:32 PM
Default Re: (igo4bmx)
IM hitting the intercooler piping that goes in the compresser
Old Feb 19, 2005 | 09:37 PM
johnzm's Avatar
Default Re: (B18c1turboedEg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18c1turboedEg &raquo;</TD></TR><TR><TD CLASS="quote">IM hitting the intercooler piping that goes in the compresser</TD></TR></TABLE>
get another pic where it hits,
and that bottom hole is probably for an oil temp, i would not use it for return
Old Feb 21, 2005 | 05:41 AM
Default Re: (johnzm)
SO will the lower hole work???
Old Feb 21, 2005 | 05:53 AM
freakie's Avatar
in one word: NO
Old Feb 21, 2005 | 05:57 AM
igo4bmx's Avatar
here is a slim line 90 degree which may help
Old Feb 21, 2005 | 06:17 AM
fipracing_com's Avatar
Post pictues of the intercooler piping and the oil drain line problem. Also look at my post on the moroso pans. https://honda-tech.com/zerothread?id=1154353
Old Feb 21, 2005 | 06:19 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18c1turboedEg &raquo;</TD></TR><TR><TD CLASS="quote">SO will the lower hole work??? </TD></TR></TABLE>
If you want to blow out the seals in your turbo use the lower hole in the pan. FYI that hole is there for an OIL TEMP SENSOR, it is NOT a drain.
Use the top hole in the pan, and get a 45 degree fitting to help you get around the intercooler piping if this dosent work you need to clock your turbo housing some to pull the piping farther away from the pan.
Old Feb 21, 2005 | 09:31 AM
NJIN BUILDR's Avatar
Default Re: (fipracing_com)
I agree that he lower one is for oil temp.And on my pan I was able to use the upper one with no problem.But I can't think of any reason you couldn't use the bottom one.The oil isn't going to back up in the line,its just going to drain into the pan.The worst case there is going to be an inch or so of oil in the line.But the line is an inch longer.The oil in the pan isn't under pressure or anything.
Glenn
Old Feb 21, 2005 | 10:32 AM
hybridsol's Avatar
Default Re: (NJIN BUILDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">But I can't think of any reason you couldn't use the bottom one.The oil isn't going to back up in the line,its just going to drain into the pan.The worst case there is going to be an inch or so of oil in the line.But the line is an inch longer.The oil in the pan isn't under pressure or anything.
Glenn</TD></TR></TABLE>
The oil MUST... repeat.. MUST drain to the pan under gravity with no restrictions.
You MUST use the upper bung on the oil pan, it has a special "drain line" to help the oil flow into the pan without being "short cycled" within the pan.
The lower bung is for a temperature sensor only!
delslow45
Apr 3, 2011 07:14 PM
Stewie
Welding / Fabrication
Nov 9, 2005 08:38 AM
fandango
Jan 20, 2005 06:20 PM
Sinner
Oct 8, 2004 09:21 AM
Steve91
May 29, 2003 08:43 AM
