sidedraft carbs solex 40mm addhe
Old Feb 19, 2005 | 09:50 AM
SQ is the SQUAD's Avatar
Default sidedraft carbs solex 40mm addhe
i am trying to get all my maprt together for my b18 motor build up. i will be running a dual sidedraft carb setup. i already have 3 solex 40 addhe carbx, one is a spare for parts , pratice and reference. my question is does any1 know the difference between solex addhe and solex phh carbs? i already have a painless wireing kit that ill be usint to wire the whole car so all the factory wiring is gone (not a daily driver street car). i was planning on building a pre odb b18a1 motor but i happened to get a free gsr head that had sand dumped into it. either was i would have had to so a slight build on the head to handle the carbs so do you think its worth lsvtec with the carbs or should i stick with straight ls? i have a msd sci ignition system to run spark. this will be a no ecu setup
Old Feb 19, 2005 | 11:59 AM
Default Re: sidedraft carbs solex 40mm addhe (h0ndavtec)
bump for help
Old Mar 8, 2005 | 07:29 PM
im honda matt's Avatar
Hey im trying to get 600 yami carbs to work any idea of any threads.
Oh yeah
bump...Ahhh **** already archived
Old Jun 2, 2005 | 10:20 PM
Default Re: sidedraft carbs solex 40mm addhe (im honda matt)
go to d-series.org, the have a pretty good carb section
unusual71
Engine Management and Tuning
Sep 9, 2014 07:21 PM
thehatchninja
May 26, 2004 04:32 PM
the jdmchop
May 26, 2003 06:00 PM
slowdx
May 12, 2003 03:21 PM
