all motor ls build up
Old May 25, 2003 | 08:14 AM
the jdmchop's Avatar
Default all motor ls build up
ok im planin on doin an allmotor setup with my b18b
and noooooo i do not wana do vtec so dont bother
im just going to do the head and i want to retain stock shortblock
i already sent out my cams to exospeed for some grinding
the head is gonna be shaved for higher compression around 11ish
they are gonna clean it and open it up a bit for better flow
i already have i/h/e safc fpr
my motor now dynos at 131whp
question is has anyone done this setup before?
any HELPFUL comments or tips are welcome
what power should i be expecting
Old May 25, 2003 | 04:27 PM
WundedSaint's Avatar
Default Re: all motor ls build up (jdmchop)
crower valvetrain, a mild cam profile, port and polish head and intake manifold, a block girdle. Chrome-moly rings. Then...most important.....aem ecu. If you rev over 8k, I suggest getting an msd box and convert to direct ignition. You can do hondata...but in the end you'll probably be spending about the same amount of money that you would have spent on an aem ecu. Don't forget the wideband o2 system. Try to make the bore to stroke ratio as square as possible.
Old May 26, 2003 | 07:45 AM
anyone have this setup?
t
t
t
Old May 26, 2003 | 08:00 AM
.RJ's Avatar
.RJ
PM 'toddreid'
he's a road racer with a built LS motor
Old May 26, 2003 | 04:04 PM
junya16's Avatar
my friend had that setup in a hatch except he used the stock ecu and ran a 14.6.....i was amazed.
Old May 26, 2003 | 06:00 PM
Lamchop0000's Avatar
Default Re: all motor ls build up (WundedSaint)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WundedSaint &raquo;</TD></TR><TR><TD CLASS="quote">crower valvetrain, a mild cam profile, port and polish head and intake manifold, a block girdle. Chrome-moly rings. Then...most important.....aem ecu. If you rev over 8k, I suggest getting an msd box and convert to direct ignition. You can do hondata...but in the end you'll probably be spending about the same amount of money that you would have spent on an aem ecu. Don't forget the wideband o2 system. Try to make the bore to stroke ratio as square as possible. </TD></TR></TABLE>
i dont think msd box is nessary at all. erick's racing civic coupe redlines at 10,800 rpm and he's runing stock ignition.
http://ericksracing.com/racecar.htm
The Stance
12
Jun 28, 2005 12:03 PM
743power
13
Aug 17, 2004 10:14 PM
94B18B1Teg
Mar 15, 2004 06:09 PM
bw54867
Sep 19, 2002 06:54 PM
