when setting timing, is it necessary to bipass the service connector?
Old Feb 19, 2005 | 05:54 AM
B16Civic93's Avatar
Default when setting timing, is it necessary to bipass the service connector?
on the c-speedracing.com website, it says that when setting ignition timing, you need to bipass the service connector in the passengerside under the glovebox. why is that? is it necessary to be done when setting timing? i'm looking to go turbo and i want to set my cams back to 0.0 and then set my ignition timing back accordingly to 16 degrees. (i have a b16 in a 93 coupe ex if it matters) thanks in advance
Old Feb 19, 2005 | 07:54 AM
zman's Avatar
Default Re: when setting timing, is it necessary to bipass the service connector? (B16Civic93)
yes it absolutely is. Only while setting the ignition timing.
Old Feb 19, 2005 | 09:30 AM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
yes, i set the timing without jumping the connector, and it was way too advanced. after i set the timing the right way, it drove a lot better. you need to jump the connector to disable the computer from adjusting the ignition timing.
Old Feb 19, 2005 | 10:12 AM
B16Civic93's Avatar
Default Re: (MugenDude)
is the service connector connected to something? what color is the connector?
Old Feb 19, 2005 | 10:14 AM
PrettyLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16Civic93 &raquo;</TD></TR><TR><TD CLASS="quote">is the service connector connected to something? what color is the connector? </TD></TR></TABLE>
the service connector is under your glover box, with a green cover to it, the plug itself is a two pin plug and is blue
Old Feb 19, 2005 | 10:39 AM
B16Civic93's Avatar
Default Re: (PrettyLude)
is the plug in the service connector? is it plugged into anything?
Old Feb 19, 2005 | 10:45 AM
zman's Avatar
Default Re: (B16Civic93)
nope. This is what it looks like.
Old Feb 19, 2005 | 01:21 PM
HeikDiesel's Avatar
Default Re: (zman)
The service connector is what you "jump" when you pull ecu codes correct?
Old Feb 19, 2005 | 02:30 PM
hondaguyef's Avatar
Default Re: (PhatAcuraIntegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhatAcuraIntegra &raquo;</TD></TR><TR><TD CLASS="quote">The service connector is what you "jump" when you pull ecu codes correct?</TD></TR></TABLE>
Correct.
Old Mar 5, 2005 | 09:20 AM
B16Civic93's Avatar
Default Re: (hondaguyef)
do you need to jump the service connector when checking timing?
Old Mar 5, 2005 | 10:53 AM
HeikDiesel's Avatar
I belive so. If not, the computer either advances it or retards it at idle so you dont get a true reading
Old Mar 5, 2005 | 12:34 PM
Jamez's Avatar
Yep, just jam a paper clip in there.
Old Mar 5, 2005 | 10:16 PM
edo3276's Avatar
you dont need to wont do anything if you do...try it
Old Mar 5, 2005 | 10:32 PM
PrettyLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhatAcuraIntegra &raquo;</TD></TR><TR><TD CLASS="quote">I belive so. If not, the computer either advances it or retards it at idle so you dont get a true reading</TD></TR></TABLE>
mortificationrock
13
Oct 7, 2007 09:08 PM
civic j
Aug 17, 2007 08:10 AM
handa
Oct 24, 2004 08:27 AM
infinate bound
Mar 18, 2004 10:35 AM
VSM EXtasy
Jul 19, 2003 10:19 AM
