uberdata
Old Feb 15, 2005 | 03:51 PM
lavo81's Avatar
Default uberdata
is it worth it to use uberdata on my zc (V-tec) engine w/ i/h/e and stage 2 act 2 clutch?
Old Feb 15, 2005 | 03:57 PM
civiccpedx's Avatar
Default Re: uberdata (lavo81)
well you can, but you really wont see a benefit. I would wait till you get a turbo or nitrous
Old Feb 15, 2005 | 04:00 PM
Soccerking3000's Avatar
Default Re: uberdata (civiccpedx)
you can gains some hp and its always nice to have the FTL (full throttle launch) function as well as datalogging, and of course its cheaper than v-afc's and has all the options of hondata
Old Feb 15, 2005 | 04:02 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: uberdata (Soccerking3000)
you'll probably get some kind of hp gains. nothing too drastic though for the mods you have.
Old Feb 16, 2005 | 06:15 PM
lavo81's Avatar
Default Re: uberdata (AzntaggeR)
i plan on going turbo in the future i think i have a p06 or a p08 ecu,which i think is compatible w/ uberdata, how much would it cost for everything to make my own chips?
Old Feb 17, 2005 | 07:39 AM
well if you soldered it yourself, it would be around 20 bucks for the chips and ZIF socket, moates.net has a kit just for that, and then get another chip for 6 bucks, and a burner for 90, so a total of around 120 bucks you can do everything hondata can
Old Feb 17, 2005 | 08:48 AM
lavo81's Avatar
is the p08 able to be chipped w/ uberdata?
Old Feb 17, 2005 | 10:02 AM
DJ_SaNdOz's Avatar
You'll also need a wide band O2 for better tuning, that's the most costly part.
Old Feb 17, 2005 | 10:18 AM
POE's Avatar
POE
Default Re: uberdata (DJ_SaNdOz)
hell yeah use uberdata to tune, u can pick up at least 5whp , prob even more.
Old Feb 17, 2005 | 11:13 AM
lavo81's Avatar
what do you mean ill need to get a wide band O2 , i have to or i should to get better tuning? what is it?
Old Feb 17, 2005 | 11:16 AM
DJ_SaNdOz's Avatar
A wide band O2 sensor gives accurate readings of your air/fuel ratio which allows you to tune much more precisely than butt dyno tuning.
Old Feb 17, 2005 | 12:03 PM
it has a linear voltage output that tells you exactly what your a/f ratio is, while the stock oxygen sensor is narrowband and can only tell you if the car is running lean or rich from the 14.7 a/f point.
kahriak
Acura TSX
14
Mar 15, 2008 10:20 PM
Mysterious
Nov 23, 2006 10:31 AM
Joeyt426
Jul 21, 2006 01:08 PM
RedTegLS
Nov 11, 2003 09:27 AM
