Acura TSX Acura TSX Sports Sedan. USDM TSX and Euro/UK/JDM Accord.
Adding Horsepower?
Old Feb 6, 2008 | 06:55 AM
kahriak's Avatar
Default Adding Horsepower?
i feel like my TSX needs a lil more power, 30-50 horsepower would probably feel much better, what are the easiest ways to boost the HP a bit?
Old Feb 6, 2008 | 07:23 AM
BlueFang08's Avatar
Default Re: Adding Horsepower? (kahriak)
I would say your best best without doing any thing big would be the Hondata Reflash. 600 bucks and it gets you 29 more hp. So do that and bolt ons and should be golden.
http://www.hondata.com/reflash_tsx.html
Old Feb 6, 2008 | 07:34 AM
evertp1's Avatar
Default Re: Adding Horsepower? (BlueFang08)
yea (BlueFang08) is right... stock TSX have around 160-170 WHP...
so do a intake and exhaust and a hondata reflash and you will get 200+ WHP
knowledge is golden bro... and the hondata website has all the dynos
Old Feb 6, 2008 | 07:44 AM
kahriak's Avatar
ok thanks that seems alot less expensive then getting a turbo
Old Feb 6, 2008 | 09:21 AM
Todd00's Avatar
I said I don't want a title!
Looks like only an 04-05 can use the reflash. Which is too bad since the later models have the faster motor.
Old Feb 6, 2008 | 12:09 PM
BlueFang08's Avatar
Default Re: Adding Horsepower? (Todd00)
Yeah the hp difference is negligible. Its only 5 hp which wouldn't make a ton of difference but they do have one out for the 06 (first year of the 'upgrade')
http://hondata.com/reflash.html
Old Feb 7, 2008 | 02:04 PM
HyeTotHeSky's Avatar
* B A N N E D *
buy another car..
Old Feb 8, 2008 | 09:11 PM
crxken's Avatar
Default Re: Adding Horsepower? (HyeTotHeSky)
lololol
Old Feb 10, 2008 | 06:36 PM
Ponyboy's Avatar
Painting Masterpieces
Default Re: Adding Horsepower? (crxken)
I think you've rec'd some good advice. Hopefully, this will help as well:
Article 1
Article 2
Old Feb 18, 2008 | 02:10 AM
eknorcal's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueFang08 &raquo;</TD></TR><TR><TD CLASS="quote">I would say your best best without doing any thing big would be the Hondata Reflash. 600 bucks and it gets you 29 more hp. So do that and bolt ons and should be golden.
whoa! 29hp output with a reflash? thanks for the info
Old Feb 18, 2008 | 11:05 AM
BlueFang08's Avatar
Default Re: Adding Horsepower? (eknorcal)
Its nice but what I like more about it is the fact that it levels out the curve much better. you dont get that dip at higher RPM and it lowers vtec so when you shift you can stayin vtec. Not have it kick int 1000 RPM before redline..
Old Feb 21, 2008 | 10:48 AM
IntegraGSR23's Avatar
purchase a HyTech Header, Cat and exhaust..
Check out my dyno thread
https://honda-tech.com/zerothread/1820453
Old Mar 4, 2008 | 09:13 PM
BOOSTEd2's Avatar
why is the '06 a better motor? they rework the head?
Old Mar 13, 2008 | 08:41 AM
Default Re: (BOOSTEd2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BOOSTEd2 &raquo;</TD></TR><TR><TD CLASS="quote">why is the '06 a better motor? they rework the head?</TD></TR></TABLE>
Cams, valves, etc..
Old Mar 15, 2008 | 10:20 PM
humara's Avatar
add some lightness.
remove unimportant things.
LU
28
May 10, 2012 09:16 AM
98or00gsr
May 2, 2007 03:02 PM
nonvteclude
Dec 7, 2006 04:47 AM
ndogg
Nov 17, 2003 05:11 AM
redciviclx14
Jun 23, 2003 12:16 PM
