uberdata
Re: uberdata (civiccpedx)
you can gains some hp and its always nice to have the FTL (full throttle launch) function as well as datalogging, and of course its cheaper than v-afc's and has all the options of hondata
Re: uberdata (AzntaggeR)
i plan on going turbo in the future i think i have a p06 or a p08 ecu,which i think is compatible w/ uberdata, how much would it cost for everything to make my own chips?
Re: uberdata (lavo81)
well if you soldered it yourself, it would be around 20 bucks for the chips and ZIF socket, moates.net has a kit just for that, and then get another chip for 6 bucks, and a burner for 90, so a total of around 120 bucks you can do everything hondata can
Re: uberdata (DJ_SaNdOz)
it has a linear voltage output that tells you exactly what your a/f ratio is, while the stock oxygen sensor is narrowband and can only tell you if the car is running lean or rich from the 14.7 a/f point.
