Oxygen sensor Idea, will it work?
Old Feb 15, 2005 | 01:27 PM
silentblackhat's Avatar
Default Oxygen sensor Idea, will it work?
I ordered the Denso universal o2 sensor off of the internet at sprkplugs.com. i just pulled the old o2 sensor off(the factory one with the plug on it). I havnt gottne mine in the mail(the ups tracking says thursday it should be here). What i am thinking is, if i cut the plug off of the o2 sensor and solder the plug onto the new sensor(matching up the wires, being careful with the 2 black ones of course) and plug it in will it be wired up right?(as in matching up the whie, green and the right black wires) any info would help on this
Old Feb 15, 2005 | 01:35 PM
pdiggitydogg's Avatar
Yeah, thats actually what youre supposed to do.
Old Feb 15, 2005 | 02:00 PM
Default Re: (pdiggitydogg)
alright, i guess im not a genius after all...but thanks
Old Feb 15, 2005 | 02:05 PM
CooBlueDAB's Avatar
Default Re: (silentblackhat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silentblackhat &raquo;</TD></TR><TR><TD CLASS="quote">alright, i guess im not a genius after all...but thanks</TD></TR></TABLE>
Well, it wasnt a question of whether or not it is a new idea, but if it was right.
So since you had the right idea thinking on your own.. I guess you can call yourself a genius for now
Old Feb 15, 2005 | 02:41 PM
SOHCD16y8's Avatar
yeah thats exactly right, they usually come with a special connector too if your not good with soldering, how much was that
Old Feb 15, 2005 | 02:45 PM
PuiPui's Avatar
Default Re: (SOHCD16y8)
hey just wanted to piggy back a o2 question here. Do all generic 4 wire o2 sensors for honda work interchangably? Meaning can i take lets say a universal civic ex o2 sensor and use it on a 99si? or do d and b series use different 4 wire o2's?
Old Feb 15, 2005 | 02:51 PM
alotawatts's Avatar
Default Re: Oxygen sensor Idea, will it work? (silentblackhat)
Next time get a direct-fit sensor...with plug. If you shop around you won't spend much more than alot of universals are priced at.
http://www.sparkplugssource.com/
Old Feb 15, 2005 | 03:09 PM
Default Re: (PuiPui)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PuiPui &raquo;</TD></TR><TR><TD CLASS="quote"> Do all generic 4 wire o2 sensors for honda work interchangably?</TD></TR></TABLE>
Yep
Old Feb 15, 2005 | 03:13 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silentblackhat &raquo;</TD></TR><TR><TD CLASS="quote">I ordered the Denso universal o2 sensor off of the internet at sprkplugs.com. i just pulled the old o2 sensor off(the factory one with the plug on it). I havnt gottne mine in the mail(the ups tracking says thursday it should be here). What i am thinking is, if i cut the plug off of the o2 sensor and solder the plug onto the new sensor(matching up the wires, being careful with the 2 black ones of course) and plug it in will it be wired up right?(as in matching up the whie, green and the right black wires) any info would help on this</TD></TR></TABLE>
Should work fine as long as the wire colors match.
Old Feb 15, 2005 | 07:10 PM
tonis56's Avatar
Default Re: Oxygen sensor Idea, will it work? (Chiovnidca)
yea it should definatley fit, just make sure that the wires match up correcly, make sure to get some good solder. bad solder can add extra unwanted resistance to the circuit and screw up your signal to the ecu. you might want to check out some weather proof crimp connectors that dont increase the resistance.
Old Feb 15, 2005 | 07:13 PM
Jimmy's Avatar
Global Moderator
Let us know how long that oxygen sensor lasts...
Old Feb 16, 2005 | 09:37 PM
Default Re: Oxygen sensor Idea, will it work? (tonis56)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tonis56 &raquo;</TD></TR><TR><TD CLASS="quote">yea it should definatley fit, just make sure that the wires match up correcly, make sure to get some good solder. bad solder can add extra unwanted resistance to the circuit and screw up your signal to the ecu. you might want to check out some weather proof crimp connectors that dont increase the resistance.</TD></TR></TABLE>]
Im pretty good at soldering, i can make good, solid connections. i dont have crappy solder either so im thinking it should be fine.
Ill let everyone know how it lasts. I read things, also tlked to various ppl, about denso and even the universal ones are pretty good from what i understand
Also, why would the plug first time sensor be so much better? i know it plugs in firectly but for the savings i would want to sodler it myself, is that a good train of thought or am i the crazy one?
dorkjoey
19
Apr 30, 2008 09:44 PM
freakasis
Mar 4, 2006 04:19 PM
Sprockets
Dec 13, 2005 11:32 AM
xDicktonesx
Jun 2, 2005 04:58 AM
