How to fix broke manual window crank? Snapped loose! **Pic inside**
Old Feb 14, 2005 | 06:08 AM
Fuster_Cluck's Avatar
Default How to fix broke manual window crank? Snapped loose! **Pic inside**
I saw this thread --> HERE
Pretty much the problem I am having, but no help offered.
Car: 1996 Cx
How the hell do I get inside the door any further? Anyone with experience with this problem? I have a straight up manual window right now. I have to slide the glass up and down by sandwhiching my hands around the glass
Thanks for any help!
Here's the pic of what is broke:
Old Feb 14, 2005 | 06:21 AM
Slopoke's Avatar
Default Re: How to fix broke manual window crank? Snapped loose! **Pic inside** (Hybrid93Hatch)
You need to replace the window regulator.
First you need to unbolt the window glass from the regulator. You will have to roll the window down a bit, so you can get to the screws.
Then you need to unbolt the regulator from the door(you can see two of the bolts in that picture. Then slide the regulator out of the big opening in the lower part of the door.
After that, install a new regulator in the reverse order. Make sure you get the window to slide back in its track properly.
Old Feb 14, 2005 | 06:52 AM
Pioneer162's Avatar
that's an easy fix with 2 people, get another actuator $10 online junkyard, probably $5 local junkyard, then follow what slopoke said. It's just a few bolts, the hard part is keeping the window steady while bolting everything back in, I did it by myself, but would have been much easier with another person.
Old Feb 14, 2005 | 02:38 PM
Default Re: (Pioneer162)
Thanks guys for the help
Can you tell me if I need the entire assembly #(5,10)?? Or do I just need the motor part and not the crossbars?
>> Window parts numbered HERE if picture not showing below <<
Thanks again
Old Feb 14, 2005 | 03:09 PM
Tim_Robbinz's Avatar
since we're on the topics of manual-crank windows, my 97 EK's driver-side window doesn't crank up all the way; like 1.5" is open and that's how far the window cranks. any suggestions?
Old Feb 14, 2005 | 03:17 PM
EXCoupe03's Avatar
Default Re: (f0uL basterd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f0uL basterd &raquo;</TD></TR><TR><TD CLASS="quote">since we're on the topics of manual-crank windows, my 97 EK's driver-side window doesn't crank up all the way; like 1.5" is open and that's how far the window cranks. any suggestions?</TD></TR></TABLE>
have someone hold the window in place, and roll the crank down...
Old Feb 14, 2005 | 03:33 PM
ThisLittleSleepeR's Avatar
Default Re: (EXCoupe03)
might have one for sale, but still on my car, havnt got around to installing my power windows yet.
Old Feb 14, 2005 | 06:55 PM
Slopoke's Avatar
Default Re: (Hybrid93Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Hatch &raquo;</TD></TR><TR><TD CLASS="quote">Thanks guys for the help
You can only buy it as the whole assembly.
Old Feb 14, 2005 | 08:02 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
Default Re: (Slopoke)
Too bad this is on a 1996, I would have shipped one of mine out to you. I just changed both of mine out a few hours ago. You'll only need one person to do, remove the glass, lifting it to the outside (away) of the car. When you do the regulators, roll the window 1/3 up, it will give you perfect access to the two bolts of the regulator.
777Brad
Jul 1, 2013 07:55 PM
jdmztrane
11
Jun 23, 2010 08:04 PM
Morasso
Sep 10, 2009 05:31 AM
VEGAN_EG
Aug 23, 2009 07:29 AM
CRX_Fenatic
Dec 9, 2006 03:27 PM
