Bouncing Temp needle?
Old Feb 9, 2005 | 10:04 PM
LSpimpTEC's Avatar
Default Bouncing Temp needle?
I've noticed that my temp needle gets really close to overheating but never goes into the red. Sometimes when i press the brake the needle drops to normal instantly, so that kind of rules out that its actually overheating. With that I've come to the conclusion that its electrical. Can someone tell me where the engine temp is taken and what wires are involved? Or tell me where it would be in the manual?
BTW...LSVTEC engine
Old Feb 10, 2005 | 07:41 AM
LSpimpTEC's Avatar
Default Re: Bouncing Temp needle? (LSpimpTEC)
bump for some HT help
Old Feb 10, 2005 | 08:00 AM
fakemike's Avatar
I had a problem like that and it was caused by a poor engine ground. I had a engine swap and the ground on the valve cover was not installed. Then there was a poor connection on the ground wire on the trans. and my temp needle would jump around. Once I cleaned up the trans ground wire and put the wire on the valve cover everything was fine.
So check to make sure that your engine ground wires are well connected.
Old Feb 10, 2005 | 08:56 AM
Aphelion's Avatar
Default Re: Bouncing Temp needle? (fakemike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fakemike &raquo;</TD></TR><TR><TD CLASS="quote">I had a problem like that and it was caused by a poor engine ground. I had a engine swap and the ground on the valve cover was not installed. Then there was a poor connection on the ground wire on the trans. and my temp needle would jump around. Once I cleaned up the trans ground wire and put the wire on the valve cover everything was fine.
So check to make sure that your engine ground wires are well connected.</TD></TR></TABLE>
If you do this and still have a problem, you may have a faulty thermostat (no big deal to replace).
Old Feb 10, 2005 | 09:42 AM
nocturnaldragon's Avatar
Default Re: Bouncing Temp needle? (Aphelion)
I wouldent think thermostate issue just yet, but i would consider that there is perhaps air trapped in the system otherwise you could have a bad thermo sending unit, but the termostate is one of the easiest to change out and the cheapest for a DIY. But i would check your grounds first like whats his name said then go off my list of things to check.
Old Feb 10, 2005 | 10:33 PM
LSpimpTEC's Avatar
Default Re: Bouncing Temp needle? (nocternaldragon)
Thanks for the responses but i no longer need them...my car was stolen AGAIN last night...i pray to god that i dont have to get another honda cuz im through. I loved my car and there are too many lazy ******* that dont want to work for what they have. i want to be away from it. i had no money as it were and this is "the nail in the coffin" financially. Thanks everyone
Old Feb 10, 2005 | 11:00 PM
Honda-Tech Balla's Avatar
Team Purple
What, are you serious? Again...no way. Do you have any leads or anything?
Old Feb 11, 2005 | 09:16 AM
Race Whore's Avatar
damn, that sucks man. I hope you get your car back . Good luck
ferrabi
Nov 27, 2017 02:07 PM
yo bj
40
Dec 23, 2010 09:32 PM
BlackShingo
May 6, 2010 07:39 AM
crxdriver89
Sep 17, 2005 07:44 AM
davejj40
Sep 9, 2004 11:40 AM
