VTEC not running as strong as it used to....need help!
Old Feb 9, 2005 | 07:18 AM
H22a4drcivic's Avatar
Default VTEC not running as strong as it used to....need help!
Recently, I had an H22 swapped into my EJ sedan. My brother had the motor in his prelude before a semi crashed into him. He was able to drive home from the accident but it was running at high temp due to his radiator gettin busted. Now after the swap, we both noticed that the VTEC does not pull as hard as it used to. Im also leaking oil occasionally from my crank seal and my filter neck. Didnt know if I need to replace my headgasket due to him running it at high temp for a little. Also, a local mechanic told me that it could be my oil pump going bad. It's a JDM motor with no mroe than 50k on it. Anyone know how to help?
I miss my hard hitting VTEC
Old Feb 10, 2005 | 07:09 AM
DOHc SIdE's Avatar
Default Re: VTEC not running as strong as it used to....need help! (H22a4drcivic)
head may be warped
Old Feb 10, 2005 | 07:51 AM
Default Re: VTEC not running as strong as it used to....need help! (DOHc SIdE)
How would that have happened? Is there a way to correct this problem without getting a new head?
Old Feb 10, 2005 | 08:36 AM
pdotjones's Avatar
it maybe because you are leaking oil. vtec runs off of oil pressure and maybe you aren't getting enough to properly engage the vtec. just an idea....
Old Feb 10, 2005 | 09:29 AM
sonicrex's Avatar
Other than the small oil leaks is the engine operating temperature normal?
Old Feb 10, 2005 | 01:34 PM
Equilibrium's Avatar
* B A N N E D *
Are you sure Vtec in engaging? Make sure everything is checking out okay, including your O2 sensor. Do you have any CELs? Oil pressure is a +! Make sure you see that jump when Vtec kicks in; otherwise you're running on your primaries.
Old Feb 10, 2005 | 03:29 PM
sickerhatch's Avatar
Default Re: VTEC not running as strong as it used to....need help! (Equilibrium)
are you running the same ecu as before??
Old Feb 10, 2005 | 03:52 PM
notstock93's Avatar
Default Re: VTEC not running as strong as it used to....need help! (sickerhatch)
If he was driving for a long period of time with the car overheating, his head may very well be warped. THis would require the head to be milled flat, a new HG (obviously) and inspection of the block/head for signs of detonation from the crazy heat.
Do a compression/leakdown test, that will tell you what you need to know.
Old Feb 10, 2005 | 06:47 PM
Mortal_Wombat's Avatar
sounds like he overheated and spoiled the motor...
heat will kill seals,cook oil, seize parts, and warp heads
Old Feb 11, 2005 | 07:02 AM
H22a4dr's Avatar
Default Re:
Thanks for all your help everyone. I'm going home from college this weekend so I'll check everything out.
BDM
Oct 20, 2009 09:02 AM
tigasin
Nov 14, 2008 11:58 PM
h22a1_julien
Aug 27, 2007 01:44 PM
DC2_ITR
Apr 27, 2007 12:55 PM
EGcivicBoy
Apr 6, 2006 02:51 PM
