idle/decelerating problem
Old Feb 7, 2005 | 09:51 AM
Race Egr's Avatar
Default idle/decelerating problem
When i come to a stop my idle will fluctuate between 800-1400 for about one minute then it will idle at 850 like its suppost to. I also just put a wideband in my car and everytime i let off the gas it spikes lean for a second then it goes back to being fine wtf could cause this? The car is a eg hatch with ls motor and has skunk2 manifold. also no cel's or mil's
Old Feb 7, 2005 | 10:06 AM
mmuller's Avatar
Mad Scientist
Default Re: idle/decelerating problem (NAPIER)
stock ecu?
Old Feb 7, 2005 | 10:22 AM
Race Egr's Avatar
Default Re: idle/decelerating problem (mmuller)
yep stock ecu i just threw the wideband on because i was bord
Old Feb 7, 2005 | 10:32 AM
mmuller's Avatar
Mad Scientist
have you tried cleaning the iacv?
Old Feb 7, 2005 | 10:44 AM
Race Egr's Avatar
nah, i havent tried that yet ive tried just about everything else
Old Feb 7, 2005 | 12:56 PM
PrettyLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">have you tried cleaning the iacv?</TD></TR></TABLE>
Old Feb 8, 2005 | 04:45 AM
EE_Chris's Avatar
Default Re: idle/decelerating problem (PrettyLude)
Do you still have the stock O2 sensor in its original location and hooked up to the ECU?
Did you install the Skunk2 manifold and then this started to happen?
Old Feb 8, 2005 | 03:55 PM
thatbluecrx's Avatar
Default Re: idle/decelerating problem (EE_Chris)
most likely the iacv... unscrew the cap on the top of it and screw down the plastic valve in there.. that should do it
Old Feb 8, 2005 | 04:55 PM
PrettyLude's Avatar
clean it
Old Feb 8, 2005 | 08:00 PM
IN VTEC's Avatar
A momentary enrichening followed by a lean spike is normal when letting off the throttle.
Old Feb 9, 2005 | 07:03 AM
Race Egr's Avatar
Default Re: idle/decelerating problem (IN VTEC)
haha thanks in vtec i just now figured this out haha
Old Feb 9, 2005 | 08:00 AM
EE_Chris's Avatar
What did you figure out? And what was funny about IN VTECs response?
Old Feb 9, 2005 | 08:20 AM
Race Egr's Avatar
well it seems like my idle screw backed it self out some so i screwed that back in and its fine. As far as in vtec's response i just realized the wideband is gonna read lean when u let off the gas as the injectors close now i feel stupid
Old Feb 9, 2005 | 02:16 PM
bbrian's Avatar
haha i coulda told u that napier
ken2830
Nov 16, 2011 04:50 PM
J_Trez
Apr 29, 2005 04:46 PM
UNKNOWN_MEMBER
Apr 21, 2005 09:32 PM
JdoggsGSR
Oct 26, 2002 12:06 PM
