Timing Belt problem!!! please help!
Old Feb 5, 2005 | 04:01 PM
1SlowSi's Avatar
Default Timing Belt problem!!! please help!
Well today we replaced all the belt and also the timing belt and tensioner. Well, after we put it at TDC and put the belt back on, it was loose. THere is about an ince or slack on the side towards the front of the car. We tried everything. Last resort.. take it all off and mess with the tensioner because it doesnt seem to be doing its job. But its brand new. What could be causing this?
At times when roting the crank pulley, the teeth on the cam gears could actuall jump a tooth.
Old Feb 5, 2005 | 04:09 PM
NJIN BUILDR's Avatar
Default Re: Timing Belt problem!!! please help! (1SlowSi)
I guess the first question is it the right belt?Do you compare it to the one you took off?
Glenn
Old Feb 5, 2005 | 04:12 PM
1SlowSi's Avatar
Default Re: Timing Belt problem!!! please help! (NJIN BUILDR)
yes it IS the right belt. At times during the roatation of the crank, it will get snug but then turn again and its loose.
Old Feb 5, 2005 | 09:41 PM
Redline130's Avatar
Sounds like you are not using the right procedure for tightening the timing belt. What engine is this?
Old Feb 6, 2005 | 12:09 AM
1SlowSi's Avatar
Default Re: Timing Belt problem!!! please help! (Redline130)
B16A2... whats the procedure. My friend is the one whos doing it. He's done it before, and says it has to be something little he may be overlooking.
Old Feb 6, 2005 | 04:49 AM
ultimatehonda's Avatar
I just did my timming belt recently on my si also.....its simple on how to tighten it.
1- Line up the cam gears and crank to the TDC marks, the cam gears for piston number 1
2- Put the belt on
3- Once the belt is on, the tensioner should be slightly lose.
4- Now rotate the timing belt 3 cam sprocket teeth counter clockwise.
5- The belt should tighten up and now you can tighten down the tensioner bolt and make sure you guys use a torque wrench to torque that bolt down to spec. I believe the helms calls for 40 ft/lbs of tq.
6- It should be good now, remember there will be some play in the belt, about 1 inch of deflection on the long side of the belt.
7- Reassmble and enjoy 3rd gear vtec.
Old Feb 6, 2005 | 08:16 AM
krazie1's Avatar
BANNED
Default Re: Timing Belt problem!!! please help! (ultimatehonda)
had the same problem myself with my LS/Vtec like four days ago and my friend was tripping too but this is the right produce bet u anything....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ultimatehonda &raquo;</TD></TR><TR><TD CLASS="quote">I just did my timming belt recently on my si also.....its simple on how to tighten it.
2- Put the belt on
7- Reassmble and enjoy 3rd gear vtec. </TD></TR></TABLE>
Old Feb 6, 2005 | 09:03 AM
slugzed's Avatar
is the head milled? if it is...then it will be off by like half a tooth to a full tooth...
Old Feb 6, 2005 | 04:06 PM
1SlowSi's Avatar
Default Re: (geezer_o6)
Well we finally got this bitch to work. It was the tensioner. Lemme ask you somethin. How important is it to tighted down the tensioner to spec?
Old Feb 6, 2005 | 04:11 PM
mmuller's Avatar
Mad Scientist
Default Re: (1SlowSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SlowSi &raquo;</TD></TR><TR><TD CLASS="quote">Well we finally got this bitch to work. It was the tensioner. Lemme ask you somethin. How important is it to tighted down the tensioner to spec? </TD></TR></TABLE>
well, if too loose it could come loose; wich would be no good.
if too tight, the bolt could break when torqued
Old Feb 6, 2005 | 04:39 PM
1SlowSi's Avatar
Default Re: (mmuller)
well we didnt use a torque wrench but its fine. The guy who did it all knows his shi*
nes1871
Oct 13, 2013 02:24 AM
thegatekeeper14
Aug 5, 2009 03:28 PM
Panoply
May 12, 2006 12:05 PM
jvonb
Dec 18, 2005 07:47 AM
drew2
Apr 20, 2005 06:17 AM
