wtf is Inverter Welder
Old Feb 4, 2005 | 04:50 PM
RACEPAK's Avatar
Default wtf is Inverter Welder
hello
as topic says....
is it an arc welder and a tig in the same machine?
what makes it different than a regular arc welder?
best regards moshik galimidi
Old Feb 4, 2005 | 05:43 PM
Engloid's Avatar
OG Fabricator
Default Re: wtf is Inverter Welder (RACEPAK)
ANY tig machine can also do stick, so that's no big selling point for whatever machine you're looking at.
Old Feb 4, 2005 | 06:30 PM
kb58's Avatar
Banned
Default Re: wtf is Inverter Welder (Engloid)
Inverter means it has high frequency circuitry inside that allows a MUCH smaller transformer; a 40lb inverter welder can do the same as a 200-300lb "normal" unit. It has nothing to do with any other features, it's just the technology used.
Old Feb 4, 2005 | 07:25 PM
fulldragcrx's Avatar
Default Re: wtf is Inverter Welder (kb58)
you use it to weld up-side-down. Sorry couldnt help it.
Old Feb 5, 2005 | 12:04 AM
mike_belben@yahoo.com's Avatar
From: not riding any bandwagons in, massachusetts, usa
kb58 has got it. line voltage on the wall is 50-60 hz. old welders used big rectifier transformers to step up the power. an invertor take the 50-60hz and immediately multiply the frequency, then stup up,, so they dont require nearly as much transformer.
inverters = reduced size, often a wider variety of acceptable input voltages, fully adjustable AC squarewave and smooth DC opertation. good ****
Old Feb 5, 2005 | 03:41 AM
RACEPAK's Avatar
Default Re: (mike_belben@yahoo.com)
so... is it better welder for personal needs than a huge tig machine? thats all?
Old Feb 5, 2005 | 07:42 AM
Engloid's Avatar
OG Fabricator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike_belben@yahoo.com &raquo;</TD></TR><TR><TD CLASS="quote">inverters = reduced size, often a wider variety of acceptable input voltages, fully adjustable AC squarewave and smooth DC opertation. good ****</TD></TR></TABLE>
Not all have the fully adjustable AC. For example, the Maxstar, and I believe even the Dynasty 200...or at least one of the models. I forget and don't have time to look now.
Old Feb 5, 2005 | 09:05 AM
kb58's Avatar
Banned
Default Re: (RACEPAK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK &raquo;</TD></TR><TR><TD CLASS="quote">so... is it better welder for personal needs than a huge tig machine? thats all?</TD></TR></TABLE>
Yes, but they are more expensive then the "old school" design. As for which one is more reliable? I don't know..., a guess would say the big traditional type is better, but that's just my opinion.
Old Feb 5, 2005 | 12:16 PM
rephrase: invertors have the ability for fully adjustable AC.
i was under the impression that the non invertor power sources were not capable of some of the things an invertor could do.
sidenote- my 40 year old 5 foot tall Linde still works pretty decently in its old age. all those functions arent worth much if you dont know how to use them.
Old Feb 5, 2005 | 02:57 PM
Engloid's Avatar
OG Fabricator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike_belben@yahoo.com &raquo;</TD></TR><TR><TD CLASS="quote">i was under the impression that the non invertor power sources were not capable of some of the things an invertor could do. </TD></TR></TABLE>
Yeah, SOME will. It's just like some tig machines have pulse and some don't... some inverters allow that AC frequency and balance changes and some don't.
I believe the inverters use less power also, but the amount of welding most of us do at home, it's not a big issue.
Old Feb 6, 2005 | 02:56 AM
RACEPAK's Avatar
Default Re: (Engloid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Engloid &raquo;</TD></TR><TR><TD CLASS="quote">
I believe the inverters use less power also, but the amount of welding most of us do at home, it's not a big issue.</TD></TR></TABLE>
i need the inverter to make my chargepipes/downpipe and once in a while a manifold.
i dont need to weld aluminum.
Old Feb 6, 2005 | 11:36 PM
mrvoodoo's Avatar
The biggest advantage of the inverters is the power consumption. It's fractional of a transformer machine. For example, we run 3 dynasty 300s off the same circuit that ran 1 350lx. The breaker is rated for 60 amps @ 480V 3PH.
Old Feb 7, 2005 | 12:39 AM
SEFIxCivic's Avatar
Default Re: (titanperf)
i run a 200dx and it has adjustable ac.
turbojeesx
Welding / Fabrication
Jul 17, 2009 05:36 AM
Tjabo
Jan 26, 2009 09:02 AM
got wide
30
Jan 1, 2009 02:20 PM
vtecspeed1320
29
May 26, 2007 07:23 PM
Mike M
Aug 26, 2004 02:13 PM
