crankshaft pulley!!!!!!! need help quick
Old Jan 14, 2002 | 08:15 PM
94civicx's Avatar
New User
Default crankshaft pulley!!!!!!! need help quick
Wondering how some of you got the crankshaft pulley bolt off to change the timing belt.
Old Jan 14, 2002 | 09:18 PM
5thgen's Avatar
Default Re: crankshaft pulley!!!!!!! need help quick (94civicx)
had someone hold the brakes, with the car in 5th gear. Then back and forth with the impact gun.
Old Jan 15, 2002 | 01:40 AM
arren123's Avatar
Default Re: crankshaft pulley!!!!!!! need help quick (5thgen)
I'm pretty sure that people have written that leaving it in gear will screw up your transmission.
I'm going to go through the same problems two months from now. I believe you can use a 19mm socket, an extension, breaker bar, jack stand, and an extremely long pole. The end of the extension would rest on the jack stand so you can apply gobs of torque with the breaker bar and long pole. Oh.. And you'll need to keep the pulley from spinning. You might be able to take off the flywheel cover and stick a screwdriver in the flywheel to keep it from spinning. If you do a search on the internet for 'civic crankshaft pulley' you'll come across a web site where it shows pictures of how to stop the thing from spinning.
Old Jan 15, 2002 | 03:04 AM
JD_B18CDX's Avatar
Default Re: crankshaft pulley!!!!!!! need help quick (arren123)
how do you loosen the bolt???
Clockwise or counter-clockwise.
Nowmally, to loosen a bolt it you spin it counter clockwise. But on some cars, (Like BMW) main bolts on pulleys spin clockwise to loosen.
Thanks!
Old Jan 15, 2002 | 03:05 AM
17secondcivic's Avatar
when i took off my crank pully i went to honda and bought this tool that will hold the crank pully from spinning and still allow you to get at the bolt with and breaker bar.
Old Jan 15, 2002 | 05:54 AM
arren123's Avatar
Default Re: crankshaft pulley!!!!!!! need help quick (17secondcivic)
Yeah, but that tool is $70. I guess its worth it if you end up using it over and over again.
DragII's Avatar
25 Year Member
impact gun worked just fine for me
Old Jan 15, 2002 | 06:05 AM
unFOB4U's Avatar
You turn it Counter Clockwise.
I used a chain wrench to hold the pulley down from moving and an impact socket connected to a breaker bar.
Old Jan 15, 2002 | 09:32 AM
arren123's Avatar
Default Re: crankshaft pulley!!!!!!! need help quick (DragII)
What kind of impact gun? Electric or air? How much torque does it put out?
Old Jan 15, 2002 | 09:44 AM
bigTom's Avatar
impact wrenches work fine for me... 1/2 take a couple seconds usually...... 1" gun takes one hit of the gun and its off!
Old Jan 15, 2002 | 10:32 AM
94civicx's Avatar
New User
Default Re: crankshaft pulley!!!!!!! need help quick (Tom)
thank you to all who answered. I used an air gun last night but the compressor could only get up to 120 ft lbs and the chiltons manual says it is torqued down to over 250 ft lbs. Will try again and eat another bowl of wheaties
Old Jan 15, 2002 | 10:56 AM
arren123's Avatar
Are you serious?! I thought the specs were around 130 ft-lbs
Dutch_commando
11
Jun 24, 2017 08:26 AM
SpOoLiNg CiViC
Jan 2, 2007 05:13 PM
originalbadbob
17
May 27, 2004 12:34 PM
xrocket21
Jun 4, 2003 04:35 PM
anumeric68
Mar 30, 2003 02:59 PM
