Can my build handle nitrous??
alrite ladies...i dont know **** about this all motor stuff since im just gettin out of the darkside...its just really starting to get played out so now it seems that all motor is the thing to do to be different...but anyway..im building an engine which is gonna b a bensons sleeved 84mm gsr block and a portflow GSR head...now i plan on running toda Cs up top and i hear they need a good amount of compresion to be effective...but at the same time i wanted to spray some juice..the pistons will b forged of course i just dont know what compression to go with
From what I have seen nitrous does well with high compression - It is all about timing and tuning, and also having forged pistons will not hurt either
Alot of drag Mustangs around here, run super high compression (14s 15s
) With like a 200 shot or larger - You should be able to have a high 11s low 12s CR with pump gas
91CRXGSR
Nov 11, 2003 06:35 PM
