Nitrous Question
Old 06-19-2002, 02:42 PM
HarryB's Avatar
Location: Where All Funky Things Come From...., Stankonia, USA
Default Nitrous Question
I have a friend that is planning on running an LS/VTEC with a NOS setup. He wanted to know if you want a higher or lower compression ratio to run Nitrous?
Thanks
Old 06-19-2002, 03:03 PM
Digitalwave's Avatar
Default Re: Nitrous Question (civicatuofw)
Lower
Old 06-19-2002, 03:08 PM
New User
gsrvx's Avatar
Default Re: Nitrous Question (Digitalwave)
Make sure he gets good tuning!!!
Old 06-19-2002, 03:11 PM
dAng!
Russ713's Avatar
as HIGH as possible
don't believe me? good. seriously, it's better to have lower compression unless you're feeling REAL lucky
Old 06-19-2002, 04:56 PM
PWRVTEC's Avatar
Default Re: Nitrous Question (Black Light)
Well since I saw no good answer I thought I would enlighten some. The higher the better to a point. Even in all motor setups. So with that being said, if using cast pistons, I would stay around 10.5:1-11:1 with forged pistons 12.5:1 would be the highest.
I have tunned and build to cars with high compression. 10.83:1 in a B18c5 bottom end, which is cast pistons and a 75 shot, and a H22 with 12.5:1 JE forged pistons with a 125 shot.
Tunning and timing is the key. If those are right then you should have no problem.
In my experience I see the stock valves being the problems.
ls-v*2
02-28-2007 02:52 PM
carlos11
07-18-2005 01:53 PM
elmo244
05-30-2005 12:57 PM
h22squeaker
06-12-2003 12:04 PM
zilverz
11-25-2002 09:49 AM
Quick Reply: Nitrous Question
