b18c-r 98spec + ls crank or b20 crank
Old Jan 30, 2005 | 01:44 PM
Rice Is Best's Avatar
Default b18c-r 98spec + ls crank or b20 crank
is this possible without changing anything else on the engine? a stock b18c-r with either a b20 or ls crank and thats its. everything else will be kept stock on the engine
Old Jan 30, 2005 | 02:43 PM
T4eg's Avatar
Default Re: b18c-r 98spec + ls crank or b20 crank (Rice Is Best)
u would need the LS rods with the ls crank. I used a LS rods and crank in my B18C with ctr pistons.
Chris
Old Jan 30, 2005 | 04:34 PM
Default Re: b18c-r 98spec + ls crank or b20 crank (BlueHatch00)
what would be the new redline for a stock b18c-r with ls crank and rods?
Old Jan 30, 2005 | 04:47 PM
clayne's Avatar
Crappier R/S ratio. Don't bother.
Old Jan 30, 2005 | 05:01 PM
LsVTeCTuRBo17's Avatar
Default Re: b18c-r 98spec + ls crank or b20 crank (clayne)
it could rev to 10,000 rpm if it makes power up there
Old Jan 30, 2005 | 05:41 PM
Professor15's Avatar
Doesnt switching the cranks also create more torque and at a sooner point in your power band due to the longer stroke of 89mm?
Old Jan 30, 2005 | 05:46 PM
clayne's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rice Is Best &raquo;</TD></TR><TR><TD CLASS="quote">what would be the new redline for a stock b18c-r with ls crank and rods? </TD></TR></TABLE>
Lower than a B18C w/ B18C crank and rods.
Old Feb 1, 2005 | 07:11 PM
ive seen gsr blocks with ls crank make more power and have a higher redline than straight gsr
Old Feb 1, 2005 | 10:38 PM
clayne's Avatar
Default Re: b18c-r 98spec + ls crank or b20 crank (LsVTeCTuRBo17)
Which doesn't mean anything.
Now have at it.
Old Aug 31, 2010 | 08:12 AM
Mota's Avatar
grave digger...
ok will im was wondering.. i have a b18c5 block with JE 11.8:1 pistons and i was told the crank i have is out of a b20
question: is this recommended? what are the pros and cons?
im upgrading everything including my rods so with this setup what rods do i have to run?
Old Aug 31, 2010 | 08:53 AM
kyden's Avatar
ls/b20 rods.
Old Sep 2, 2010 | 06:36 AM
Meister vtec's Avatar
I have a 82mm bored b16b block with an ls crank and rods plus rs itr pistons with minor modifications.
I cant even express how much better my ride is when compared to my buddy with his poor *** gsr.
I also put 20k of extreme hard drving on it too, so I dont give a **** what others say,
Old Sep 2, 2010 | 12:04 PM
airmaxbri's Avatar
do it
Old Sep 2, 2010 | 02:10 PM
blackeg's Avatar
i run and ls crank and ls eagle rods in a jdm gsr block. rev to 9000 too dont have any problems.
you have to plug the oil squirters and I use ls/b16 oem bearings
rdssk8rcs1
Oct 13, 2008 04:52 PM
jdmsijdm
Dec 19, 2004 10:53 AM
Art701
Mar 19, 2003 06:47 AM
1.8T_EG
Dec 25, 2002 07:35 PM
sappsycho
Jun 26, 2002 01:24 PM
