VTEC and Speedometer not working.
Old Jan 30, 2005 | 08:43 AM
gsr984dr's Avatar
Default VTEC and Speedometer not working.
I recently had an exedy clutch and flywheel installed in my car and now my VTEC and my speedometer doesn't work. I read in the forum that it could be caused by low oil pressure so I immediately did an oil change on the car and it's still experiencing the same thing. Now my check engine came on.
Does anyone know what the problem could be? Has anyone experienced this same problem?
Old Jan 30, 2005 | 08:59 AM
00000xxx's Avatar
Default Re: VTEC and Speedometer not working. (gsr984dr)
what code are you throwing?? maybe a sensor isn't hooked up or all the way on
Old Jan 30, 2005 | 09:04 AM
T4eg's Avatar
Default Re: VTEC and Speedometer not working. (ctr610)
try looking at your other post in the EG section. You got some good replies.
Chris
Old Jan 30, 2005 | 09:06 AM
gsr984dr's Avatar
I'm new to all this stuff. How do i check for codes? I also double checked all the sensors (plugs) that connect to the tranny and that general area and all seem to be plugged in.
I forgot to mention this is a 00 Si. are there any sensors inside the tranny that maybe they did something to?
Old Jan 30, 2005 | 09:22 AM
00000xxx's Avatar
double check the speed senor on the back of the tranny, make sure the wires arent twisted, you cant miss the senor its the only one on the back of the tranny right below the throttle body.
do a search on how to check codes, its better to read a write up then have me explain it
Old Jan 30, 2005 | 09:29 AM
00000xxx's Avatar
https://honda-tech.com/zerothread?id=978933 integra
https://honda-tech.com/zerothread?id=682412 civic
not sure what you have so here ya go
Old Jan 30, 2005 | 10:28 AM
blackeg's Avatar
my bet is on vehicle speed sensor
Old Jan 30, 2005 | 12:02 PM
00000xxx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">my bet is on vehicle speed sensor</TD></TR></TABLE>
same here
its either a bad connection, not connected at all, or a break in the ciricuit
Old Jan 30, 2005 | 10:03 PM
PrettyLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ctr610 &raquo;</TD></TR><TR><TD CLASS="quote">same here
its either a bad connection, not connected at all, or a break in the ciricuit</TD></TR></TABLE>
make sure that there is no moisture in the plug that plugs into the vss
Old Jan 31, 2005 | 05:08 AM
Plugs's Avatar
I had this same problem not too long ago. You will need to Change out your VSS. Its located on the back side of your tranny.
Old Feb 2, 2005 | 04:13 AM
shauniewalnuts's Avatar
Default Re: (Plugs)
your vtec doesnt work because you have to be up to a certain speed in order for it to engage, its prob. the vss, did they plug it back it and installing it?
Old Feb 2, 2005 | 05:35 AM
gsr984dr's Avatar
Default Re: (shaun311)
I know about being up to speed. I think they (the repair shop) must have done something when they took off the tranny to install the clutch.
I took it back on Monday and they are going to replace the VSS. I'll let you all know when it's fixed.
Old Feb 2, 2005 | 10:25 AM
thatbluecrx's Avatar
Default Re: (gsr984dr)
could just the speedo cable... just happened to me
Old Feb 2, 2005 | 01:53 PM
Default Re: (thatbluecrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thatbluecrx &raquo;</TD></TR><TR><TD CLASS="quote">could just the speedo cable... just happened to me </TD></TR></TABLE>
unless its a 92^ they are electronic
Old Feb 2, 2005 | 03:04 PM
gsr984dr's Avatar
I just got a call back from the shop. They said it was the VSS. The only problem is that none of the Honda dealers out here have that part in stock.
I'll have to wait till tomorrow to get my car back.
Old Feb 2, 2005 | 03:52 PM
TURBOSOHC1085's Avatar
its more than likely ur speed sensor. i had a friend that experienced same problem.switched out senor and worked fine.tha also would cause ur vtec not ot kick in.
gsr984dr
11
Jan 30, 2005 10:17 AM
MugenB16A2
Oct 12, 2003 10:44 AM
Mentat Ghola
Jan 13, 2003 10:38 PM
dinglenuts22
Aug 14, 2002 03:04 PM
eTec
Jul 17, 2002 06:10 AM
