Busted a ... how do I get it out?
Old Jan 14, 2002 | 11:28 AM
servion's Avatar
Default Busted a ... how do I get it out?
I look under my hood at my b18c /w a dragIII kit, and one of the bolts that holds the wastegate to the exhaust manifold has busted! There is still the bottom part of the bolt stuck in the manifold, and I don't know how to get it out. One of my buddies suggested getting a reverse-threaded drill bit and try to use that to drill it out of the hole, but I'm afraid that the bit will just drill a hole in the bottom of the bolt and it will still not budge. Any thoughts?
Old Jan 14, 2002 | 11:37 AM
rainforest's Avatar
Default Re: Busted a ... how do I get it out? (servion)
listen to your friends they have told you the right info just reverse thread it.
Old Jan 14, 2002 | 11:40 AM
Geezer's Avatar
You can try something like this:
http://shop.store.yahoo.com/tmt/drilkitscrew.html
...and if you have my usual luck, then you can take the manifold off and tote it to a machine shop, where they can drill out the remains of the bolt and put a helicoil in.
Old Jan 14, 2002 | 12:26 PM
PyroVTEC's Avatar
New User
Default Re: Busted a ... how do I get it out? (Geezer)
Get an easy-out. You can go to a local hardware store or Home Depot, tell the guy in the hardware section that you're trying to get a screw out whose head cracked off.
You'll need a drill, and a small drill bit to drill a small pilot hole in the middle of that broken bolt. Once that hole is in place, the Easy-Out goes in, put your drill on reverse, press down hard on the drill, and slowly "drill" out. The Easy-Out is reverse threaded, so when you're twisting it in a counterclockwise direction, the bit goes down into the bolt (which is why ya drilled that pilot hole in the first step), grabs a hold of it, and easy it comes out!
Old Jan 14, 2002 | 06:39 PM
fixhondas's Avatar
If there is some bolt exposed-I would soak some penetrating oil in it and try some parrot jaw pliers or a stud extractor- don't drill it until all other options are "exhausted". A cobalt drill bit will withstand the heat if it is a hardened bolt if you prefer drilling. How did it break? If it broke going in- an esay out might work- if it broke coming out- easy outs and reverse thread bits will get you nowhere.
Old Jan 15, 2002 | 10:47 AM
servion's Avatar
Default Re: Busted a ... how do I get it out? (fixhondas)
well, I was lucky..... the easy-out did the trick! I don't know how it borke... it was just broken when I popped my hood yesterday morning... but its good to go now. thanks all
Old Jan 15, 2002 | 12:14 PM
rioninja's Avatar
Exhaust bolts tend to just get weak after a while due to the heat. Even if they're not really seized, sometimes they jsut like snap.
TravisBiggie
Jun 23, 2012 01:30 AM
theauthor17
Aug 8, 2008 11:47 AM
phthalo
May 24, 2007 11:53 AM
95GSRTT
Feb 3, 2005 11:48 AM
GrandMarkie
May 17, 2002 12:53 PM
