raising compression using stock head gasket
I want to raise the compression on my b18c5. It's bone stock with the exception of a cai. I was reading about using a stock head gasket and removing the rivets and using a layer from that.
Which layer to use? I read in one post that the outer layer is thinner then the middle... how true is that statement? Is there anyway I can calculate an estimated compression using measurements of the different layers?? I know I could do a compression test before and after but if it's not going to be significant (.2 or something) then I don't want to waste the time.
Thanks!
Frank
Thanks!
Frank
it won't quite be .3 difference just by pulling the middle layer.. running a one-layer (bottom layer only) will yield closer to a .3 difference.. and remember, when torqueing with a thinner gasket you generally want to do it in more stages ( 4 or 5 opposed to 3) to insure that you're getting an even crush on the gasket..
.... I know I could do a compression test before and after but if it's not going to be significant (.2 or something) then I don't want to waste the time.
Thanks!
Frank
Thanks!
Frank
You're better off leaving your stock headgakset alone or just buying an aftermarket one (spoon/mugen).
The best way to raise compression is either buy going GSR head on your B18C5 or changing the pistons to something that has a higher dome.
good luck.
or just shave your head
>>Correction of cam timing needs to be made if you mill a head, especially when a head is milled down a lot.<<
Is there a general rule with regards to cam timing and milling the head or installing a thinner gasket? At what point does milling the head for more compression become detrimental unless timing is advanced?
I vaguely remember a formula with regards to advancing the timing x.x degrees for every xx thousanths milled off the head. Is there such a formula? Thanks!
petty$rep
Nov 11, 2006 02:20 PM
