Rod bearings
Old Jan 27, 2005 | 06:17 PM
faSHOwidIT's Avatar
Default Rod bearings
If I change the bearings for the rods, will I have to resurface the crankshaft? Is it really necessary?
Old Jan 27, 2005 | 06:23 PM
mmuller's Avatar
Mad Scientist
Default Re: Rod bearings (faSHOwidIT)
unless there is something wrong with it you dont have to
Old Jan 27, 2005 | 06:56 PM
faSHOwidIT's Avatar
Just changing rod bolts and doing a bearing change for safety. So it's ok to just change the bearings?
Old Jan 27, 2005 | 07:07 PM
unsungsohc's Avatar
Default Re: (faSHOwidIT)
sounds like a good plan. no need resurfacing the crank unless scarring or wearing is visibly occurring as stated above. make sure to check your clearances upon reassembly
Old Jan 30, 2005 | 02:42 AM
faSHOwidIT's Avatar
Oh yea and what are the specs for the measurements?
Old Jan 30, 2005 | 09:04 AM
mmuller's Avatar
Mad Scientist
Main Bearing
Blue 2.013-2.010 mm
Black 2.010-2.007 mm
Brown 2.007-2.004 mm
Green 2.004-2.001 mm
Yellow 2.001-1.998 mm
Pink 1.998-1.995 mm
Red 1.995-1.992 mm
Rod bearing
Blue 1.510-1.507 mm
Black 1.507-1.504 mm
Brown 1.504-1.501 mm
Green 1.501-1.498 mm
Yellow 1.498-1.495 mm
Pink 1.495-1.492 mm
Red 1.492-1.489 mm
Old Jan 30, 2005 | 08:50 PM
faSHOwidIT's Avatar
Uh oh...how do I know what color to order?
Old Jan 30, 2005 | 09:22 PM
PrettyLude's Avatar
you have to measure it with plastigauge or with a dial indicator
NWDyno
Sep 24, 2015 08:15 PM
tegracer19
May 30, 2007 09:27 PM
made in JAPAN
Jun 16, 2004 07:54 PM
UncleBen'sRacing
Mar 8, 2003 10:17 PM
Brian_92GSR
Apr 2, 2002 01:53 PM
