Rod bearing question
Replacing the rings in my ef and figured I'd throw in some new rod bearings at the same time. So I got the color of the bearing sizes I need but when I go onto ebay/king/acl...whatever aftermarket size, it just asks if I want standard or oversized bearings.
What is the thickness of standard bearings? The crank has never been turned but still curious as to what the thickness of these standard rod bearing size is.
Re: Rod bearing question
for D-series
Rod bearing thickness by color:
Blue 1.510-1.507 mm 0.0594- 0.0593
Black 1.507-1.504 mm 0.0593- 0.0592
Brown 1.504-1.501 mm 0.0592- 0.0591
Green 1.501-1.498 mm 0.0591- 0.0590
Yellow 1.498-1.495 mm 0.0590- 0.0589
Pink 1.495-1.492 mm 0.0589- 0.0587
Red 1.492-1.489 mm 0.0587- 0.0586
Yeah I got that information. I'm wondering what the thickness of the standard sized bearings? When you go on for say ebay, and look at bearing kits they come as standard (or oversized) I'm asking what the thickness of the standard is?
you would need to measure them or call teh manufacturer. Standard is usually sort of close to green. if you want to go with the colors you go to honda.
TurboKneeGrow
03-18-2008 07:22 PM
