resleeving blocks
Old Jan 25, 2005 | 08:26 PM
TurboxDC2's Avatar
Default resleeving blocks
has anyone resleeved there block with stock sleeves...im wonder if there is a big price difference between stock sleeves and aftermarket sleeves...if so how much?...or is it not possible???...the block i have that needs resleeving is a b18c
Old Jan 25, 2005 | 08:41 PM
cheesebug's Avatar
Default Re: resleeving blocks (TurboxDC2)
Hate to tell you, but there are no such things as Honda sleeves that I know of. I've resleeved blocks with Darton MID sleeves before. When you cut the Honda sleeve out it's ribbed. They are cast in with the aluminum. I know there are aftermarket sleeves that still let the open deck and are cheaper if you want to go that route, but be sure to check for oversized pistons first. From what I can tell you should be at least able to get another mm over stock bore. Just because a company doesn't advertise these sizes, it doesn't mean they still don't make them.
Old Jan 25, 2005 | 09:45 PM
TurboxDC2's Avatar
Default Re: resleeving blocks (cheesebug)
i cant bore the block because the sleeve is cracked about 1 inch long from the top
Old Jan 26, 2005 | 05:02 AM
cheesebug's Avatar
Well, I'd go with the MID sleeves since you're going to be going through the trouble of having it sleeved anyhow.
Old Jan 26, 2005 | 06:16 AM
NJIN BUILDR's Avatar
Replacing the stock sleeve with a replacement style sleeve is much cheaper and easier than a performance sleeve.Most any automotive machine shop can handle this.The sleeves are simple designs and either has a small lip on the top to locate it or are simply straight and locate by leaving a ledge at the bottom.If it was an ls or b16 I'd just say find another block and sell yours to someone who wanted a performance sleeve.But b18c's blocks go for $400 or so and you can get your block repaired for a third of that.
Glenn
silverprop
Feb 3, 2010 06:04 PM
92VXeg
Nov 21, 2008 10:28 AM
Boostn B20
Aug 20, 2008 03:28 PM
_Endless_
Mar 11, 2004 06:37 AM
jpkl
Oct 15, 2001 06:26 AM
